Question about Akai PDP4225M 42 in. Plasma Television
I need an antenna for Akai tv model # PDP-4225M
I need an antenna for model number PDP-4225M. Where can I get one, I don't have cable or satellite tv
3 Suggested Answers
SOURCE: LOOKING FOR Q-14 IN POWER BOARD AKAI MODEL PDP 4298
you might want to look here, I have no idea if they are any good but they say they have the parts. http://www.shopjimmy.com/catalogsearch/result/index/q/PDP4298ED/
Posted on Aug 17, 2009
SOURCE: With no picture but only sound on my Akai PDP 4294
Try replacing the Y-sustain board. Might have to replace buffers attached to it too. Have you had it diagnosed? My picture went out and I replaced the power supply board. Worked for 2 weeks then acted up again. Got a different power supply board. Same thing 2 weeks later. Was told it now was a bad Y-sustain board. Replaced y-sustain board. Worked OK for about 2 hours then started having picture issues. Not the same issues before power supply or y-sustain problem. Was told that you might have to replace buffers attached to y-sustain when you replace y-sustain. Tired of dealing with it and only watch a couple hours a day, so I don't always have the problem unless I watch the TV for a long time. Will eventually replace buffers to see if that works. I would definitely find a place that gives free estimates or close to free to get a technician diagnosis. Then you can decide if you are able to do the work yourself.
Posted on Aug 09, 2010
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
How do i hook up coaxial cable
Straight into the RF connector on the tv. If you have a converterbox, satellite or cable box,connect to the input, box first, and then from the out point from box into the RF connector of you TV. Hope this works!
Nov 29, 2009 | Akai PDP-4247 Television
Aug 17, 2009 | Televison & Video
HD ready?
It was not a problem. It is just a question. Is it HD ready or not without a converter box or cable?
I will go to a store and ask a tech if you can not answer.
thanks
Jan 14, 2009 | Akai LCT3201TD 32 in. LCD Television
I have a AKAI CFTD 2085 model tv. Is it digital or do I need a converter box?
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Dec 04, 2008 | Akai CFTD2085V 20" TV/VCR/DVD
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Difficult time programing remote
Try the UN11000 remote call customer service at 800-726-4405
Dec 25, 2007 | iLO LCT32HA36 Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PDP4225M 42 in. Plasma Television Logo
60 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
