Where to connect fire alarm to a combination starter with a hand/off/auto/switch
  • 53 Answers
This sounds like a connection to a generator. The fire alarm system does not control the generator, but monitors the status. The types of conditions the fire panel can monitor depends on the generator. Some generators have schematics on the access door but it would be best to consult the manual for the generator for capabilities and locations of the generator output relays. Modern generators have programmable output relays that need to be set up by the installation company. If no documentation exists, call the generator manufacturer.
The connection to the alarm system will either be through programmable monitor modules or hard-wired zones back to the main panel.
Posted on Jan 24, 2015
  • 147 Answers
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Posted on Sep 13, 2009
My aftermarket alarm won't disengage
If the alarm isn\'t hooked to the ignition (The vehicle will still start when the alarm is going off). Just look under the dash for a black box usually about the size of a deck of cards. Unplug the harness and you will have deactivated the alarm. If there is a starter interrupt you\'ll need to dig deeper. Near the ignition switch harness there would be a Green/Red wire (Ignition) and a red wire (Starter). There is often a T-Tap connection to the ignition wire while the starter wire would be cut and routed to the alarm brain (Black box). Simply unplug the t-tap connection from the ignition wire and restore the connection to the starter using a connector.
Most stereo shops would be able to resolve the issue. Our store charges only $35 for a basic alarm removal.
Best of luck. Ben
Elite Auto Solutions.
Jan 06, 2014 | Cars & Trucks
Wont start
Does it crank and not start or won't crank at all? If it won't crank at all then the starter or solenoid that fires it could be defective. Also if it won't crank could be the neutral safety switch in the transmission keeping it from starting. Is there an alarm on this car? Alarms (especially aftermarket ones) usually have a starter interrupt circuit that prevents the ignition switch from activating the starter when they are set. Factory alarms may prevent the ignition system from firing if they are set or defective. Anyone been doing "non-standard" wiring under the dash recently??? Check that first then check the large gauge wiring connections, starter, ignition switch wiring and alarm(s) in that order and you should find your problem. This issue can be fairly simple but can also quickly turn into an complicated electrical troubleshooting nitemare. You may want to consider having it towed to a reputable shop for professional attention.
May 12, 2013 | 2000 Nissan Altima
Nissan maxima 1998...car wont start sometimes...keep trying 5-10 times then starts. Dealer guessed it was poss the alarm. can i turn off alarm...they said i have to cut or take out entire alarm...
I had the same problem with my maxima and the alarm I replaced my starter and haven't had any problems with it yet and my alarm is back and up running as we'll so I would start with your starter.... I took mine to the auto parts store tested great because it decided not to act up at the time....but dead again all the sudden.... took starter out it was shot and put in the new one fires up everytime now alarm works great hope this helps
Apr 18, 2013 | 1998 Nissan Maxima
97 chevy tahoe truck wont start from the key
The ignition switch is probably bad and not letting the fire get to the starter from the key. I say this because you are getting fire at the starter or you would not be able to short it across the solenoid. Hope this helps.
Apr 06, 2013 | 1995-1997 Chevy Tahoe Ignition Starter...
Horn and parking lights flash off and on randomly after auto is started and while driving
sounds like alarm system problem is there a car starter installed and not properly installed or antivol system and do you have a hood switch that is broke try to disconnect hood switch to see if this will stop as well if you have a car starter installed maybe to unplug and testthe original alarm system or contact dealer for tsbs on alarm system problems
Dec 30, 2010 | 1999 Toyota Avalon
1995 silverado and the truck will only the auto-start alarm
it seems like you've got a security issue. there's either a problem with the remote starter module or with the truck's immobilizer. take it down to the car stereo shop that installs alarms and remote starters and see if they can diagnose it for you.
Feb 17, 2010 | 1995 Chevrolet K1500
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
2000 Toyota Rav4, just purchased. Has a two button Toyota FOB for door locks, alarm and remote starter? . The vehicle has a OEM Toyota remote starter installed but I don't know what combination of buttons...
My ex girlfriend had a factory installed honda remote strt on her vehicle. It was activated by hitting the lock button two times in succession. Some vehicles use a combination of the lock-unlock buttons. try using some combinations on the remote, many "oem" remote starts are installed by aftermarket installers so who knows what they did as a start function, it could also have been changed by the previous owner.
Aug 23, 2009 | 2000 Toyota RAV4
Quietsource 25kw Staring problem In auto mode or manual
Sounds like the you have no spark since when you force the engine to crank it never fires. The low battery light come on because the 2 sec of cranking lets the voltage get lower than the alarm threshold.
I'd connect a spark tester to either of the plugs and try a manual start, if you see sparks replace the plugs, if you get no sparks then you've got to troubleshoot the ignition modules and the kill wire that comes from them.
Regards,
Carl
Feb 23, 2009 | Generac Electrical Supplies
Engine is not fireing-up
If you have a car alarm, it may have a starter kill feature that diables the starter. First you'll have to disable the alarm, then check and try starting the vehicle. You can always turn the alarm back on when your finished.
Nov 16, 2008 | 1999 Acura TL
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
