Question about Polaroid TLA-04011C 40 in. LCD TV
No response when i push the power on button. just the red standby
I connected my pc to my polaroid 1080p lcd and when i went to switch to the correct input the screen went black. now it will not turn on exept for the red standbye power light. is there a reset button? i have already checked the fuse and is is in tact. i also unplugged it for a couple of hours hoping it would somehow reset itself but no luck in that either
The same thing happened to mine! We need to get everyone together that had the same problem and sue the company for a new TV or our money back! e-mail me with any suggestions. aheavyhitter@cox.net
Posted on Nov 02, 2009
  • fraserscrimgeour
    fraserscrimgeour Jan 12, 2014
    same here, but now my red standby light doesnt urn on
Those arnt solutions, but neither is mine :P
but the same thing happened to me :c
i would love a solution for this
Posted on Jun 21, 2010
I had the same problem.
Posted on Dec 06, 2009
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
TV LCD 42" POLAROID TLX04244B (RED LIGHT ON, NO CHANGE TO BLUE AND NOT START)
Double check your connections. General rule of thumb, if the problem changes after you are in the set, it is probably something you did.
As for your original problem, it sounds as if you either have a bad capacitor or the tcp onthe panel is going bad.
Mar 20, 2013 | Polaroid Televison & Video
Polaroid 3700 lcd
GOT SAME PROBLEM NOW IS THERE A FUSE WHERE POWER CORD PLUGS INTO THE SET ON THE BACK MINE HAS A GLASS FUSE NEXT TO THE PRONGS THAT COME FROM TV YOU HAVE TO USE A SCREW DRIVER TO POP IT OUT SHOWS A PIC OF IT IF YOU DON'T SEE IT DON'T TRY TO POP IT OUT
Feb 24, 2013 | Polaroid FLM-3732 Television
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Polaroid TLA-04011C 40 in. LCD TV Logo
522 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
