Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
MY TV IS ON STANDBY WHAT DOES IT MEAN AND HOW DO I GET IT TO WORK I CAN HEAR SOUND AND CHANGE CHANNELS BUT NO PICTURE STANDBY LIGHT IS ON
My sony videoscope xbr was in storage for a while. I brought it home and let it warm up before I plugged it in. now the standby light blinks all the time. I have sound but no picture. any idea what to do?
Posted on Mar 20, 2010
Umm what i did was disconnect the tv from the outlet n connect it back then presss the powere on and keep it pressed for 10 second or till you see the picture hope it works =D standby means not fully off something like power saving if u dont wann turn it off all the way
Posted on Dec 02, 2009
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
When i turn it on i hear sound but no picture can hear sound for about 15 sec then it turn off on its own then the timer standby lights 10 times and continues to blink 10 times then short pause then ten...
Usually when a TV starts producing sound but no picture a couple of faults can be attributed to it.
Least among these causes is the contrast or brightness. If either of them has been set to the lowest then you would get volume but no sound and if the channel has been changed to another station with no station then the blinking is bound to happen.
In another scenario if the picture IC in the unit has blown then you have to refer the unit to an expert to fix it. But be rest assured that the blinking lights are as a result of the TV being on a station with no reception.
Hope this solution has been helpful?
Sep 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Standby light flashing
check the owner's manual, you'll see what the indicator light code means. More than likely it's your tv lamp.
Apr 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
When i on the tv by remote the red standby light turns into green and i hear the tv sound but not picture and after a one or two second the green light turns into red. The tv goes into standby mode when i...
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Jul 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
965 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
