Question about HP LaserJet 2500 Printer
Printer is stuck, only flashing orange caution light
Was in the middle of printing a job and it just stopped.  A sheet was about 1/4 fed, so I pulled that back out and ever since the printer has been unresponsive.
Have tried resetting (green button held during power up), powering up and down several times - all to no avail.
All toners cartridges and the drum are fairly new (not depleted yet).
Am at a complete loss as to what is going on.
  • 38 Answers
Dear eBailey,
Problems may have regarding pressor roller
Posted on Dec 11, 2007
My brother 2140 printer has a flashing red error light
You need to go into the control panel and find your printer to delete the print job. That would cancel the printing. You may need to also turn the printer off for a few minutes, then turn back on. This should solve your problem.
Oct 14, 2017 | Brother Office Equipment & Supplies
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Flashing Orange light will not stop printer will not print
    THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
    Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
    Printer won't print documents. Green light on
    Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
    Feb 10, 2010 | Dell 1710n Laser Printer
    Won't photocopy / warning light flashing /
    The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
    Jul 16, 2009 | Canon PC170 Copier
    Hp deskjet 5652 not printing, orange light flashing continuously
    1. Check to insure the cover is shut down completely.
    2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
    3. If the carriage moves to the middle, release the ink cartridges and replace.
    4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
    * * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
    This link will take route you to HP's support and more troubleshooting techniques for your printer.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
    Hope this helps..
    God Bless.......
    Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
    Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
    check ur orange cartredge
    & check ur orange printer head & clean ur printer head
    ur problem is solve
    because this problem is only cartredge & prinater head
    Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Paper feed
    Something is stuck in between the
    tray and rollers possibly torn paper
    in one of the corners
    try with just a few sheets of paper
    Once you remove the jam
    wilthout breaking any plastic
    parts it will work okay
    Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
    HP LaserJet 2500 Printer Logo
    183 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
