Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
I have a bosch aqua star aq125-hx natural gas. I'm having a problem with it "lighting". Sometimes it works on the first try, sometime 3-4 times.I've cleaned the in-take screen. The unit doesn,t have a standing pilot or electronic. It starts on water pressure and I belive mine is around 50psi
2 Suggested Answers
KenjiFox
  • 142 Answers
SOURCE: bosch aquastar Aq125-hx does not
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Posted on Jan 07, 2011
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
We have a bosch tankless water heater in a 1600 sq ft home...it works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
Aug 29, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Failing ignition on Bosch Aquastar AQ125-HX tankless on demand water heater. Carefully followed all directions on device to best of ability. Gas supply is full and on. Water pressure should be...
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch water wizard 16 - gas still runs after water tap turned off
Sounds like a flow sensor may be bad. It may be registering flow when there is none and it sending signal to ignitor and gas solenoid that there is.
Apr 04, 2017 | Bosch Water Heaters
I have a Bosch Aquastar 125ng with the water turbine ignition. When you turn on the water, it works exactly as expected. If you shut off the water and then turn it on again, it will not always start. It...
i have an aqua star 125 ng an the pilot lights and stays lit but the main burners wont fire up when i turn the water on i have good water pressure so i kind of stumped and i just rebuilt the diaphram in it also
Dec 11, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
339 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
