I want to clean the filter inside my whirlpool washer GHW9200LW
    Sergeant:
    Novelist:
  • 197 Answers
There should be a small door on the front o the washer on the left. Open the door, and turn the plug anticlockwise, remove the filter and empty, refit the filter and close the door.
Posted on Sep 13, 2009
My whirlpool ghw9200lw keeps tripping the outlet breaker.
Possible there is a short in the circuit or when it comes to a certain cycle. You can check for moisture within the washer, is so clean it dry after disconnecting, use a dryer to warm off . Also remove and reconnect the harness to the program controller unit.
Finally check the motor capacitor, check for motor jamming, check lines to the drives and element.
Jan 22, 2013 | Whirlpool Washing Machines
Whirlpool washer model GHW9200LW, THE CODE HF comes up ,tried the recommended fixes from the troubleshooting guide, but no luck
HF = High Fill
This can be caused by using non HE detergent in your front load. Put the washer in a cold rinse for a couple of cycles to clean the excess soap and try the cycle again using HE detergent. If the problem returns you may have a pressure switch or hose that will have to be replaced.
Aug 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer (model # GHW9200LW, serial #CSM 4604196) is blinking "F02," which means there is a drain problem. My husband disconnected the drain hose and cleaned it. The washer continues to blink...
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mod.ghw9200lw has f-02 code
This is a draining error code. First start by cleaning out the drain filter. This is done by removing the access panel on the bottom of the front cover. Make sure to check the hose behind the drain filter, as socks and small under garments love to hide there. Also check the impeller on the pump, if any tines are missing the pump must be replaced. If all is good with the pump, re-install the drain filter and run the washer through a rinse and spin cycle.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in Whirlpool duet GHW9200LW
The part you are referring to is called the door seal, or door boot seal, or door diaphragm
Look in yellow pages for whirlpool service if you live in the u/k.
Please rate my solution.
Thanks.
Jul 29, 2009 | Whirlpool GHW9200L Front Load Washer
Control lock light on
take a good look on control panel i don't remember which button you should push and hold for 3 for 5 sec. to lock or unlock control panel (it also called child lock) let me know it help or not. thanks....
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need instructions to replace the rubber boot (door bellow) on the whirlpool duet washer GHW9200LW
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
Jul 04, 2008 | Whirlpool Washing Machines
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
