Question about Konica Minolta magicolor 2400 Laser Printer
Usb cable I need a usb cable to connect the printer to the computer. Can you tell me what the cable is called?
  • Nike Merritt May 11, 2010
    It's called a USB Cable, what other information do you need?
    Scholar:
  • 77 Answers
The cable is called a "usb cable" - most printers don't come with them these days - but you can pick one up at any local electronics store for around 10 bucks - or online...here's a link for one that will work on amazon
http://www.amazon.com/Belkin-F3U133-10-Hi-Speed-Cable-Feet/dp/B00004Z5M1
good luck - hope this helps!
Posted on Sep 13, 2009
  • 147 Answers
USB Printer Lead.
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
Oct 17, 2008 | HP Office Equipment & Supplies
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
Lemark x5650
You will need a USB cable to connect the printer to your computer. The USB has Type A on one end and Type B on the other. You can purchase this from any electronic shops around your area or you can also call Lexmark Technical Support to request for one. Lexmark printers that are capable of wireless connection have a Wifi light (usually found on the upper right corner on its front face). But before you're able to connect wireless successfully, you will still need to connect the printer to your computer temporarily with the usb cable for configuration. Hope this helps.
Jun 10, 2010 | Lexmark X5150 All-In-One InkJet Printer
Need help to install my lexmark x2470 printer
Install your cd for printer into your drive, plug power cord for printer in but do not connect usb cable to computer, run your software to install drivers for printer, software will tell you when to connect usb cable to cable, follow software instructions you should be able to use printer when done.
Feb 06, 2010 | Lexmark X2470 All-In-One InkJet Printer
The Printer cannot communicate with the computer.
you need to reinstall the printer driver follow this steps.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Sep 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
My computer does not detect MFX 1430 printer. I think I need the usb driver for the usb cable.
Yes you will need drivers to run a "Local" set-up which is what a usb connection is called. Install drivers BEFORE connecting usb cable. You can download drivers from Muratecs web site www.muratec.com
Jun 30, 2009 | Muratec MFX-1430 Copier
Connecting to hp f4180
Most likely it was a USB cable. You can find them in the stores. Make sure you get the right type that is on the printer. As they come in a few different sizes and shapes. Although most knowledgeable people at the store will probably know what kind you need for a printer. What is the make and model anyway? I'll look it up and tell you the exact one to look for.
Jan 30, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My computer tells me I am not connected to a usb cable
Were you able to solve your problem?
Brian
Aug 01, 2008 | Computers & Internet
Connecting my new PIXMA MX700 to my computer
Please read your owners manual.
It's very simple to connect a printer, and ever simpler to read the part of the manual that tells you how.
Perhaps you should get a friend to help you. If I say "Power Cord" and "USB Cable" will you know the difference? If not, I probably couldn't explain it to you through type.
If you think you could tell them apart, then do this:
1. Make sure you have a USB cable. Most printers don't come with a cable to connect to a computer. If yours did, you'll have two cables in the box. The USB and the Power cables.
If you don't have a USB cable, you'll have to go buy one.
2. Put the CD into your CD ROM drive, follow the instructions. When the computer tells you to, plug your USB cable into the back of the printer and the computer. Plug the power into the printer. Turn the printer ON.
The computer should detect the printer. Follow the instructions on the computer screen.
That should be all there is to it.
Dec 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Konica Minolta magicolor 2400 Laser Printer Logo
80 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
