Question about Philips 51PP9200D Television
Philips projection HDTV 51PP9200D/37. Convergence problem
I have a Philips projection HDTV 51PP9200D/37. It has a problem with the convergence. The picture has red and green "ghost" images while watching anything. I have tried adjusting it but it only moves up and down. not left or right. I tried everything the manual said but nothing has worked. It started happening the other day without any prior problem or anything happening to it. What is wrong and how can I fix it?
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 13, 2009
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
Dec 19, 2012 | Philips 51PP9200D Television
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Color is to orangy and not clear
Convergence are dead.Must know how to solders?Must change 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 26, 2010 | Philips 51PP9200D Television
My 'Philips 51PP9200D/37' TV picture is distorted and bowed along the bottom. There is like a "bubble". It has been there for over a week. It went away for the night last night but is back this AM.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Philips 51PP9200D Television
Philips 42PF7320A/37
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
CRT Rear-Projection Red Vertical Alignment
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 11, 2008 | Philips 51PP9200D Television
Philips 51PP9200D/37 not comming on
Check the site www.TvRepairKits.com. They have put together a couple of kits to fix the chirping set/dead set condition. If you don't see your model listed send them and email and they will build a parts kit for you.
Dec 11, 2007 | Philips 51PP9200D Television
Philips 51PP9200D Television Logo
265 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
