Question about Ovens
How do I remove the hinges from a Blanco BOS402
How do I remove the hinges from a Blanco BSO402 electric wall oven. I have removed the door but now need to remove one of the hinges that is broken
  • 4,059 Answers
Slide the oven out from the wall. You should be able to remove the hinge from the side.
Posted on Sep 13, 2009
Testimonial: "Not quite right but thanks anyway, I have removed the door as per instructions and worked out how to disassemble the door by removing all the screws"
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
HOW DO I REMOVE THE OVEN DOOR & HINGES FROM ST GEORGE UEOLAS ELECTRIC OVEN PLEASE
Most oven doors can be removed by opening door and pulling straight out. The hinges are attached to the oven frame not to the door. Some oven doors have screws that are attached to the hinges at the bottom of the door on the inside that need to be removed, then pull straight out.
May 16, 2016 | Ovens
Removed door of oven (Blanco BOSE752) for cleaning, unable to get the door back on. Is there any tips, have followed the instructions in manual. Help.
make sure the hinge is in the mid open spot then position the door on them and slid down till it stops . close door .
Jul 12, 2015 | Blanco Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Removing oven doors
  • Trying to clean a late 1970s Hotpoint GE Wall Oven Model "R K746 013AD" and
  • I do not know how or if the oven door is removable.
  • See photos.
  • I am able to remove the side of the door hinge attached to the oven but am not sure about the hinge attached to the door.
  • I do not have the owners manual.
Jan 01, 2014 | Ovens
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
413 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
