Question about HP Photosmart C3135 All-In-One InkJet Printer
Need instruction on how to scan photos. Once scanned I plan to save the photos to a thumb drive.
How to scan a document
Place the document the same way you would for a copy. Then use the step by step guided instructions under the scan button options. You will need a thumb drive computer or some other device to save your document to.
Dec 05, 2015 | Canon PIXMA Office Equipment & Supplies
Tip
How to Scan a Picture on an All-in-One Printer
Instructions<br />Things You'll Need:<br /><br /> * Computer<br /> * All-in-one printer <br /><br /> 1. Blow the dust from your scanner and printing area with canned air. Clean the scanner bed and the underside of the document lid with a damp, lint-free cloth before scanning.<br /> 2.<br /> Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.<br /> 3.<br /> Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.<br /> 4. Close the lid.<br /> 5.<br /> Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.<br /> 6. Click the scan button on your computer's scanning software window. Some all-in-one printers need you to press the scan button on the printer itself; check the manual before using.<br /> 7. Get a preview of the scanned image up on your computer monitor. This might happen automatically depending on your software settings; if not, you will have to prompt your computer to display one.<br /> 8. Correct small defects such as red-eye in the image. Save extensive changes for later with dedicated photo-editing software.<br /> 9. Accept the scan and save to your hard drive. Remember to put your picture away.<br /><br />If I could be of further assistance, let me know.<br /><br />Thanks,<br /><br />LETMEFIXIT<br /><br />
on Feb 09, 2011 | HP Photosmart C4580 All-in-One InkJet...
Put photos on facebook? Not from phones, or cameras with simscards, just old photos.
Scan them onto your computer, save them to your computer. Go to your facebook page, hit upload photo, go to browse button, go to where you stored your pics ie. photos or desktop, find the pic you want to upload then click on it, hit ok and it should upload for you.
Jan 22, 2015 | Cameras
Need instructions for setting up scan options
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it my documents (my pictures) for photos most common
hope this helps you
Sep 19, 2011 | Computers & Internet
I want to be able to scan photos on to facebook but dont know how
The Lexmark X2670 printer does not have the capability of scanning photos directly to Facebook. However, you can scan your photos to your computer and save the scanned file. Then post the saved file to your Facebook account.
  1. Open the top cover, and then load an original document facedown on the scanner glass.
  2. Close the top cover to avoid dark edges on the scanned image.
  3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
  4. From the printer control panel, press the Scan button.
  5. Follow the instructions on the computer screen.
After saving the file, open your Facebook account and post your saved photos.
Jun 20, 2011 | Lexmark X2670 All-In-One Printer
How do I scan a document and send it to my computer
Since you didn't mention any specific, I am unable to give you the specific instructions. Well, I hope you've already installed the Hp Softwares/drivers to run your printer and it's feature. If so, please follow this LINK and follow the instructions. Click the name of the operating system/s to follow the instructions for the selected operating system, eg. click Windows XP if you have installed it on Windows xp computer and so on. Here's another LINK for instructions on how to scan without using Hp software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 06, 2011 | HP Photosmart C5180 All-In-One InkJet...
How do scam a piture unto my computer
  2. Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.
  3. Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.
  4. Close the lid.
  5. Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.
Oct 25, 2010 | HP SMART BUY TOUCHSMART 9100 AIO23IN T6570...
How to scan photo to save on computer ?
Instructions Things You'll Need:
  • Pictures to scan
  • Computer
  • Scanner
  1. Step 1 ** Prep your photos **
    What we're going to do here is take all your photos and put them onto one 8 1/2 x 11 sheet of paper.
    So take some tape and put it on the BACK of a photo. Then put that photo on the 8 1/2 x 11. You want to do it on the back so it won't ruin your original.
    Then repeat this for the other photos you've got. And make sure you leave some space between the photos. This is so they don't get stuck together or overlap.
    If you have lots and lots of photos that won't fit on one page, then use multiple pages to hold them. In other word, put as many as you can on a page.
  2. Step 2 ** Preparing to scan**
    Now that you've got your photos on an 8 1/2 x 11 piece of paper, it's time to put it onto the scanner. And be careful when holding the paper so your photos don't all fall off.
    Now carefully lay the paper with the photos facing DOWN on the glass of your scanner. And it doesn't matter if you're using a flatbed scanner or one of those combo printer/scanner/fax machines.
    TIP #1: I suggest making sure your glass is clean and free of streaks beforehand. Otherwise, you may see lines or distortions when the photos are scanned.
    TIP #2: Do NOT feed the paper through the sheet feeder if you have one. This may jam the feeder or damange your photos. So make sure you only lay the paper on the glass!
  3. Step 3 ** Ready to scan **
    The only thing left to do now is actually scan your photos. Now depending on your scanner software, you may be able to scan a specific area.
    In other words, many scanning software programs allow you to select the region or area of the paper you want to scan. If so, then I suggest you use this to crop your image around a specific picture. This will make the process easier.
    When you've done this, scan it! Once it's on your computer, you can edit it to make it ligher, sharper, etc. Or save it as is. Then you'd repeat this process for the next picture.
    If your software won't allow you to scan a specific area, then you'll need to scan the entire page. Do it! Once the image is on your computer, then you can use editing software to copy a specific portion to a new file. This is what you'll need to do to get individual photos.
    As an alternative, you could crop the one you just scanned and then save it. Then rescan the whole page again and crop it to the next picture. Both ways work the same, so is your choice which way to go.
Hope it will help you :)
Jul 23, 2010 | HP PSC 1350 All-In-One Thermal Printer
How do I scan a pic from printer to computer?
Things You'll Need:
  • Computer
  • All-in-one printer
  1. Step 1 Blow the dust from your scanner and printing area with canned air. Clean the scanner bed and the underside of the document lid with a damp, lint-free cloth before scanning.
  2. Step 2 Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.
  3. Step 3 Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.
  4. Step 4 Close the lid.
  5. Step 5 Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.
  6. Step 6 Click the scan button on your computer's scanning software window. Some all-in-one printers need you to press the scan button on the printer itself; check the manual before using.
  7. Step 7 Get a preview of the scanned image up on your computer monitor. This might happen automatically depending on your software settings; if not, you will have to prompt your computer to display one.
  8. Step 8 Correct small defects such as red-eye in the image. Save extensive changes for later with dedicated photo-editing software.
  9. Step 9 Accept the scan and save to your hard drive. Remember to put your picture away.
Apr 08, 2010 | HP Photosmart C4240 All-In-One InkJet...
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP Photosmart C3135 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
