Question about Kenmore Refrigerators
Have to remove drain pan every other day will overflow onto floor
  • 28 Answers
Air and moisture is getting into fridge/ check door seals. replace if needed
Posted on Sep 13, 2009
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
Drain pan fills up and overflows onto floor
Is the pan "level" under fridge? If not, it will not hold the amount of drainage that is put out and spill onto the floor.
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
Why is my drain pain overflowing?
on most fridges, you should be able to empty drain pan. Remove grill on bottom at the floor, and see if pan will slide out. Good-Day!
Jul 26, 2014 | Roper Refrigerators
Why is water leaking from unit
The drain is plugged up. This causes water to overflow out of the drain pan and on to the floor. Water comes from the evaporator coil, when it condenses water vapor out of the air to remove humidity. If the drain is not plugged up, then the air conditioner is not level. Meaning it is tilted forward or backwards enough so that the water cannot reach the drain properly and it overflows onto the floor.
May 18, 2014 | Fedders A6P09S2A Air Conditioner
How to access drain pan
The panel at the bottom (kick panel) is removable. The pan is located inside. The water on the floor may indicate that the pan has overflowed or it may have cracked
Dec 28, 2012 | KitchenAid KSRD25FK Side by Side...
Our machine is collecting water but I have a drip coming from the bottom onto the floor? It is coming from the behind the collection area?
This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
Sep 28, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
May 31, 2009 | Maytag MSD2656G Side by Side Refrigerator
Water drains onto floor instead of drain tube
can t imagine that the problem is withthe machine, i would actually think that perhaps your drain is backing up and overfiling in to the pan. seems like a more likely scenerio, next time it happens check the walll directly behind the unit undert he drain line if its wet, then id say overflow issue
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Feb 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
