Question about ATI RADEON X1600 Pro 512MB AGP Graphic Card
Initial Connector Broken(Input from wire that goes to PSU and Computer.
3/4 of my connectors are broken, if i need to sauter new connectors on, what do i need to use, or just use conventional sauter and smack it on there.
  • 1,601 Answers
You need electronic solder.. 60/40
Posted on Jan 09, 2008
Turn a delta 400lb
I don't think this model has any on/off switch on the side of the case.
Ensure that the PSU is setup for the correct a.c. input voltage.
I assume that it is the same model as here
with a 20 pin mainboard connector.
Working from this reference
the PSU (removed from computer) may be turned on by connecting the terminal from which the green wire emerges to any of the terminals from which black wires emerges, for example pin 16 to pin 15 in the diagram (a straightened out paper clip is often used for this purpose)
Alternatively, it easier to use a psu tester
When connected in your computer find the connector which goes to the front panel on/off button. If if it's connected simply press the on button on your computer. If its not, establish from the m/b manual which are the pins to the on/off switch and connect them together for a moment. The psu should come on.
Apr 17, 2014 | Computers & Internet
Webcam broken wire
your best option is to buy a new webcam for 20$ and attach it to your laptop, now that being said if you just cant live without your current camera you will have to find the replacement camera and cable open up your computer using a screw driver locate where those wires are plugged into your motherboard at remove those wires and install the new wires and lead the wire back up to spot where your camera goes then reassemble the laptop this is kind of tricky because sometimes these wires can be sautered on and non replacable also if you dont glue in your new camera right it wont face you correctly
May 15, 2013 | Computers & Internet
Gas guage shows over full all the time
You have lost the ground input to the gas gage. Its the black wire coming from the fuel pump connector at the fuel pump. Either the wire is broken or the input to the body control computer is broken, thus creating high Resistance on the input wire. The computer will think the tank is full, a shorted wire would indicate lo Resistance and read empty. Locate the fuel pump connector and jumper the black wire directly to the body (ground) and turn the key to run, check gage. If reads normal the wire is broken betwwen fuel tank and its ground location.
Jan 29, 2011 | 2000 Pontiac Firebird
I have a 2000 ford explor and all my windows stopped working at time
I would suggest checking the wiring that goes from the drivers door to the body (rubber ribbed hose between door and body). Pull back the rubber hose and pull hard on each wire and you will most likely find a broken one that you can repair with a crimp style connector. I see this happen alot on explorers) Sometimes if you take a 2-3" wire of the same size as the broken one and put a crimp connector at each end it makes it easier to do the repair because the new wire adds length and makes it easier to work it(the wire) thru the rubber hose.
Hope this helps!
Apr 02, 2010 | 2000 Ford Explorer
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Broken connector on new USB keyboard
I would contact the store that sold you the keyboard, and found out where you can find replacement parts. I went to the iOne website and there wasn't a support section, that I could find.
May 22, 2008 | Computers & Internet
Green plug won't connect to audio out/headphone jack
Yes.. It is a broken connector. What to do is to purchase a replacement 1/8 mini connector at an electronics supply store such as Radio Shack, cut off the broken connector and strip the ends off the wires and solder the wires onto the new connector.
Oct 09, 2007 | Boston Acoustics MicroMedia Computer...
Computers & Internet Logo
216 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
