Question about Poulan Garden
Clutch brake not releasing - Poulan Garden
  • 28 Answers
Clutch needs to be disasembled and cleaned and lubricated / chek to see if any springs are broken
Posted on Sep 13, 2009
How to set and release the brake
You would depress the clutch/brake pedal all the way down and then pull or activate the brake engage lever or linkage. To release it normally all you have to do is fully depress the clutch/brake pedal and the linkage or lever will automatically disengage.
Jan 20, 2016 | Garden
1998 Corvette with manual transmission. when letting clutch pedal out, car stalls every time either in 1st or reverse
Give it more gas before letting the clutch out? Release the parking brake? Check for binding brake/parking brake parts if brake is released? Dammaged differential?
May 26, 2012 | Cars & Trucks
Press brake pedal hard and release the n/s/f and o/s/r brake locks om, press clutch pedal twice and they release
This is a system on subarus to stop you rolling back when on a hill with the clutch depressed . The brakes should unlock as you release the clutch. There is a cable attached to the clutch fork in the engine bay. This goes to a brake actuator on the left hand side. If it isnt working corectly check the cable for wear or fraying. It may need adjusting by a mechanic.
Apr 28, 2011 | 1998 Subaru Forester
Clutch pedal travel is excessive. Sits about 2"
A clutch pedal takes MUCH more travel to function correctly, when compared to a brake system...
A clutch needs to be replaced (maybe) when it SLIPS, Chatters, Or fails to release...
Other than that, the clutch will need to be adjusted to allow for total release of the relese bearing when pedal is released, and full disengaugement when pedal is depressed....Have a mechanic look at the adjustement, as proper adjustment gives longer clutch life. This is a periodic adjustment item.
Apr 03, 2011 | 2001 Subaru Impreza
I have a Whirlpool Ultimate Care II LSQ7533JQ1 washing machine. It agitates and drains but does not spin. I checked the motor coupling is not worn out nor broken. This is a two speed washing machine. ...
This is a neutral drain direct drive machine which drains the water first prior to spinning. After draining out the water completely, the motor pauses then restarts to spin the tub. It is possible that the problem is in the lid switch. If the motor is running during the spin cycle then the lid switch is good, otherwise it is indeed the problem.
The problem can be either in the brake particularly the cam driver or the clutch assembly. The clutch hub is attached to the spin pinion gear and as the spin pinion gear turns, the clutch hub also turns. The clutch lining is forced against the clutch hub by the clutch spring. As the clutch hub turns, friction between it and the clutch lining causes the clutch lining to turn. As the clutch turns, the tab that holds the clutch spring on the lining, contacts the brake cam driver, releasing the brake. The tab on the clutch lining remains in contact with the brake cam driver, holding the brake released and then providing power to the spin tube through the brake release.
The basket will not spin if the brake cam driver is broken because the brakes cannot be released. If the clutch spring is weak, the friction between the clutch hub and the clutch lining is not sufficient for the clutch tab to push the cam driver and release the brakes.
Check and replace, if necessary, the brake cam driver and the clutch assembly particularly the clutch spring and the clutch lining.
Dec 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
1996 vulcan 1500, clutch goes away
if your oil is too thick , your clutch will sleep and go away .
if the clutch is old , you obviously will have the same problem .
please explain your problem when you ride
Sep 27, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
Rear brakes sticking on
hill hold,it stops the car rolling backwards when youre on a hill with the clutch in and releases when you let out the clutch taking off,it can be adjusted if its not working correctly,very handy feature to have
Apr 15, 2009 | 1991 Subaru Legacy
Clutch won't engage and back wheels locked
sound like back brakes locked up burn up your clutch.
Jul 28, 2008 | 1996 Ford Aspire
Garden Logo
48 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
