Question about IBM ThinkPad T23 2647 Notebook
IBM T23 Laptop went into hybernation when battery
Laptop went 9into hybernation when battery discharged. How do I get it back? Turns on, but screen remains blank. Pushed every key and combo of keys I could think of. Removed battery and reinstalled and recharged.
  • 615 Answers
Are you going to use hyernation again...it takes lots of space and may freez your computer if you do not have a space use safe start and look at c: and see how big is the hiberfil.sys do not delet it if you are going to use it again if not try to disconect. temp. by typing "powercfg -h on"
Hope that work for you please post your outcome
Posted on Sep 13, 2009
MY IBM LAPTOP T23 2647ASKS FOR BIOS PASSWORD WHICH I DO NOT HAVE WHEN EVER I SWITCH IT ON.NOW I CAN NOT USE IT.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Nov 26, 2010 | IBM ThinkPad T23 2647 Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
T23 Ibm laptop no video
Hello !
Test with an external monitor. If it works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | IBM ThinkPad T23 2647 Notebook
IBM T23 Thinkpad battery does not charge
If you have some electronic skills and are not afraid to open up your laptop then I might have a solution for this. It could be a known problem in T23 where one component is loosen from the mainboard and in that case it can be fixed with a soldering iron. Other possible cause is blown fuses. But to confirm this you have to remove the keyboard and do the check.
Nov 14, 2008 | IBM ThinkPad T23 2647 Notebook
How to repair ibm thinkpad t23 laptop screen no light
Yes you have no backlight. The screen is all dark but in the back you can barly see it. You inverter is bad on you thinkpad. You need to replace it. I have a IBM thinkpad 600e and i got one for $9.95 so they can be cheap. They are located under the lcd. When you open it up it is there or can see that it is attached to the light dimmer swicth so you will know that is it. Thats your problem
Sep 20, 2008 | IBM ThinkPad T23 2647 Notebook
My Screen Is Black When I turn the Laptop On
need a inverter maybe. t23 lcd inverter check ebay diy project need a screw driver thats it
Apr 14, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Fan turns on and off rapidly
The fan cycling problem on the T23 series usually indicates a loose solder or missing inductor which is usually on the underside beneath the PCMCIA slot. If you replaced the mobo yourself you may have flexed what is a weak solder joint loose - you will need to pull the board and resolder this or have someone else do this for you. You can sometimes get the laptop to start by flexing the assembled laptop gently around the PCMCIA slot and if so then that almost always means an inductor problem. You can find some photos by googling (images) "T23 mobo" or "T23 motherboard".
Feb 19, 2008 | IBM ThinkPad T23 2647 Notebook
My IBM T23 Laptop screen keeps going off (hibernating or sleeping?)
What operating system you running? I assume XP. If you go to start > settings > control panel > Power options (I think). You can change the options on how long before the screen turns off and stuff in there. For the other problem just right click on your desktop, and click "Properties". Adjust the screen resolution there.
Nov 08, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
