Question about Ruud UBHC Air Conditioner
Cannot reach the temperature setpoint in heating sequence
I have the RUUD model : UBHC-17J14SFA and a white rodgers single stage thermostat.
there is 2 circuits energizing 2 pairs of heaters 1&3 and 2&4 via 2 relays, the relay 1 energizes the heaters 1&3 and the fan, it loocks to work fine because the fan starts normally.
The relay 2 is energized only when the watt restrictor enables that.
In my case, the problem should be otherwise the restrictor or the the relay2.
question : after 5 years running time of this model, the part to replaced is it watt restrictor or relay ?
to short the watt restrictor, is it a feasible solution ?
is it better to replace the thermostat with the double stage one?
thank you for your help, please use my email adress lahloukha@hotmail.com
    Sergeant:
  • 288 Answers
I think what you are trying to ask is should you use a 2 stage thermostat or stick with a single and just double the stages on a relay to work at the same time. As long as the relay can handle the amp load, there is no real need for a 2 stage heat system, unless you are concerned by the efficiency of $$. If I am missing the question please reply.
Posted on Dec 18, 2007
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How do I fix my my white rodgers f178 thermostat, no heat
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department.
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to heat then and raise the setpoint above room temperature. There may be up to five minute delay before the thermostat clicks in heating If the thermostat click this means its not a thermostat you have a problem with your heating equipment call your installer. If the thermostat did not click the unit should be replaced.
Let me know if you need anything else.
Jan 11, 2013 | White Rodgers White-Rodgers 1F85RF-275...
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its not cooling down even though I can hear the motor running
Jul 17, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
RUUD UBHC-17J14SFA HEATING PROBLEM
you may have airflow issues, verify the inlet and outlet temps with the unit running on start up, if the unit exceeds the "rise" allowable then the safety devices "overtemp" will take the firing circuit off line until it cools down. The acceptable mfg. rise is listed on the nameplate inside the burner chamber, (generally on the side wall)
Jul 17, 2009 | Ruud UBHC Air Conditioner
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
RUUD (Protech Model 500) Thermostat Single Stage Not Programable
problem is not the thermostat, thermostat is an on-off switch that happens to work on temperature. Your furnace is locking out. cycling the heat off switch resets the micro-processor in the furnace. You need to diagnose the problem in the furnace, to go further we will need the model and approximate age of the unit
Dec 11, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
341 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Dennis Boxerman
John Tripp
John Tripp
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
