Question about Vacuums
Brushes wont turn, therefore not sucking up dirt
    Problem Solver:
  • 8 Answers
Check to see if you have a broken belt which is connected to brushes to make them turn.
Posted on Sep 13, 2009
It seems to be blowing the dirt away instead of sucking it in?
Sounds like it has blockage somewhere in it causing low suction, therefore brush 'blows' dirt away instead.
Jan 27, 2016 | Oreck Vacuums
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Don't sucks ditrs
Is the brush turning?
If not, replace the belt, check the brush roll make sure the ends turn freely. Other wise, are the filters clean? The hose and/or the dirt inlet by the brush roll may be clogged.
May 11, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
193 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
