Question about Kodak EASYSHARE G610 Thermal Printer
How can i charge the camera with the printer dock, i put it on the dock and it ask if i want to transmit which i dont, just looking tocharge the battery
How tocharge my kodak model6490
You can charge the battery with the charger that came with the camera. Or you can charge the battery with the camera dock. For that to work, you should switch off the camera. While the charging is stopped as soon as you switch on the camera.
If you don't have a dock nor a charger, you could buy a new universal battery charger. Several brands do have universal camera battery chargers. Those new chargers sense what voltage your battery needs and will give no more.
Nov 05, 2013 | Kodak EasyShare DX6490 Digital Camera
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
When you buy a m753 kodak does it come
Kodak sells three different package versions of their cameras. You can purchase one of their cameras with an adapter but no dock, with adapter and dock, or with adapter and printer dock. The dock and printer dock are also available on line (try eBay) as accessories. The dock is an extremely handy accessory, allowing automatic charging and computer connection. The printer dock though, at least in my experience, is a cumbersome and unreliable method of obtaining low-quality photos.
Nov 07, 2009 | Kodak Easyshare M753 Digital Camera
When i shut down the com. my zen wont start up anymore
When you let the battery totally run down on these, it has to sit and charge, looking quite dead, for a little while before it has enough of a charge to boot-up again.
Dec 28, 2008 | Creative Labs ZEN Vision:M Digital Media...
Recharge batteries in camera on g610 printer dock?
Hi, I think I can answer your question, i just tried something with my camera and camera dock.
My camera came with a Kodak battery pack(pack that looks like 2 batteries connected together). When I place my camera with this battery pack in it on the dock, a green light comes on on the dock and the batteries begin to charge. However, when i place any other rechargeable batteries in the camera on the dock, it has no effect, my theory is that it must be a battery pack, possibly by the same manufacturer so that it will charge correctly
Dec 20, 2008 | Kodak EasyShare C613 Digital Camera
I have a kodak c610 camera with the c613 dock but it will no longer charge when i put it on the docking station.
check the contact points of your docking station and your camera. check if there are any obstruction. try dusting it off and recheck
Aug 09, 2008 | Cameras
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
Battery won't charge on printer dock any more?
I had a similar problem. If you look in the battery compatment you will see a small switch in the keyway that gets pressed down by the key (the plastic rectagualr bump out) on the side of the battery, if the battery is loose the switch does not get pushed down and the dock does not recognize the battery as a Kodak Batery that it should charge. I solved the prblem by taping a singe piece of paper on the opposite side of the battery so that when it slides into the slot it pushes the switch down, I've nver had a problem since.
May 13, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Jan 21, 2008 | Video Cameras
Cant charge camera on dock or print photos
the dock won't charge batteries that are ni-mh kaa2hr or Li-ion battery pack - so check that
about the printer's ability to recognize the cam, try this.. remove batt, put cam on top of dock (when cameras are on a dock, they can use the dock's power so you can print pictures without batteries) check if somethign will come up on the cam screen
if not .. either would need to be sent in for repair. a digital rep will advise you to send both so the repair center can check
Mar 09, 2007 | Kodak EasyShare CX7525 Digital Camera
Kodak EASYSHARE G610 Thermal Printer Logo
54 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
