Nakamichi receiver AV500
Dear expert, I have receiver Nakamichi AV500, It wasn't used for a year. It was used once and packed in it's box. Now when I try to use it again It wont work. There was no sound from the speaker even no noise. Please help me. Tx
Did you make sure your Speaker A or B switch is pushed in? This happened to me a few times where I thought the receiver was broke, but someone had accidentally turned of the speaker A switch...
Posted on May 02, 2008
How do i control a Nakamichi RE-1 with a GE Universal Remote?
The Remote has Learning Mode - change the operation of the remote to Learning Mode and program the key buttons appropriately by pressing buttons on the receiver with remote pointed at the receiver
Jun 19, 2015 | Nakamichi RE-1 Receiver
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
May 07, 2014 | Yamaha RX-V995 Receiver
Nakamichi re 10 capacitor value
Its 10000uF 63V and use dual capacitors.
May 28, 2012 | Nakamichi RE-10 Receiver
Hi, when I plug my TV's optical out into the Nakamichi AV8's optical input, and switch to "DVD/Optical" (after hitting "Digital Input" buttno) ... no sound comes out. I have...
Maybe assign it?
If the digital TV-related audio actually originates elsewhere (Cable Box?) you could skip the TV and use the Cable Box as the audio source. Nothing is gained by flinging an audio or video signal around the room to be handled (but not improved) by any device. I have no video entering my receiver and nothing but bare bones analog audio going to my TV in case I want to just watch the news or something else lo-fi.
Jul 14, 2011 | Nakamichi AV-8 5.1 Channels Receiver
My ML200RTW isn't generating 12VDC anymore. It receives the 120VAC signal and the timer works (it hums and keeps the time). I can manually activate the timer switch, but no matter what position I put...
Bad news.
There are no repair parts for broken power pack.
Terminals A and B should test for 12 volts, as you have determined.
Terminals C is for photo eye operation only.
If transformer hums, that is signal that it is working.
It might be possible to open case and somehow find the copper wire from the transformer that will produce 12 volts again, but nobody has reported being able to fix power pack.
Please add a comment and say if you are able to do this successfully.
ML series power packs have 5 year limited warranty, and you usually need the receipt.
Open following link for troubleshoot steps plus warranty links, money-saving tips for next power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Intermatic 200W Power Pack & 12v...
I'm trying to program my Dish Network remote to my Nakamichi AV-8 and can't seem to make it work. I know I'm doing it correctly because I've tested it with another receiver. Any ideas on which code I...
We would be happy to help with that. Here is a list of someof the codes that we have for your Nakamichi Receiver: 671, 748, 750, and 649.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Nakamichi Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Nakamichi Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 27, 2010 | Nakamichi AV-8 5.1 Channels Receiver
Got a Nakamichi AV-2 receiver at a garage sale, no manual however. Can I use it to power a 5.1 surround system for home theatre?
I could find only little information about this receiver, but it seems that is supports only 4.0 Dolby Pro Logic.
May 12, 2010 | Nakamichi AV-2 Receiver
NAKAMICHI MB100 CD disfunction with the message "D-ERROR"
Try these guys based in Hong Kong. SunLight Car Stereo Co Ltd (sunlightltd@yahoo.com)
Jan 15, 2009 | Nakamichi MB100 Mobile Tuner / 6 Disc...
Av500 need a compatible cd player
You don't need a Nakamichi CD player. Any CD player will work. Just look at the manufacturing date, you don't want one made before 2000 or so, they got a lot better about that time. The Sonys are generally good and easy to find.
Dec 17, 2017 | Nakamichi AV-3S Receiver
No input signal
ensure your tv is in av1 mode
May 26, 2007 | Archos AV 500 400-Hours Video Recorder
391 people viewed this question
 Grubhead
Grubhead
