HP Photosmart 475 InkJet Printer Logo
Posted on Sep 12, 2009
Microboards GX1 disc publisher CD print alignment out.
We have a microboards GX1 disc publisher. This uses an HP photosmart 475 printer in it's system. It prints OK but the CD print alignment is out. The printer preferences only allow up to 1.4 mm adjustment and it needs at least 3 or 4 mm. As it seems to only allow .std or .stt type files from Sure Thing s/w we can not seem be able to do a work around by using a straight offset jpg image. Sure Thing creates a non removable mask so no image adjustments are useful here either. Any ideas? To fix or for a work around?
cheers
Ric
Microboards G3 doesn't recognize new cartridge
wipe the printed board on both the cartridge and its locater board see if that works make sure there is no inc or any ting in its way
Is there a print driver available for Windows Vista for the MicroBoards DX-2 Disc Publisher?
According to the manufacturers web site, Vista and Windows 7 are not supported.
Regards,
Matt
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
4helpful
MICROBOARDS PRINTER LANGUAGE MONITOR........UNABLE TO READ DEVICEID......................this is the error i get when trying to print to my Microboards GX auto printer
The Microboards G3 is the worst duplicator I have ever owned. It has worked a total of 4 times, no response from the company, software is terrible and faulty and I'm pretty much over it. Good luck.
3helpful
Microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
I have a microboards DX-1 Disc Publisher and as the disc comes through the printer and is being printed the disc moves sideways and the rest of the printing is crooked. It appears that the printer head is...
I'd recommend calling their support line at 952-556-1639 and asking for a guy named Brochu. I own a DX-1 and he was very helpful and was able to walk me through the process on the phone.
Pf2 ink cartridege recognition issues
Sounds like you have either a defective ink cartridge, or the sensor that recognizes the cartridge is either dirty, broken or out of alignment.
Microboards will help you out at no charge if your printer is still under warranty. Otherwise you can contact an authorized Microboards repair center like
http://www.techwaredist.com/repairshop.asp
Pf3 microboard printer not working
Use Windows XP Professional or 2000 professional for best results.
- techwaredist
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
k24674
Grand Canyon Tech
Grand Canyon Tech
