Question about Garden
I need to replace the strings on my trimmerI know the new string needs to be wound onto the spool in a certain direction, but can't remember how
  • 279 Answers
There should be an arrow showing the direction. Look closely at both ends of the spool. Good luck ...Lee
Posted on Sep 14, 2009
Testimonial: "I'll check it out....Many thanks"
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
Tip
Trimmer/Weed Eater String Replacement
"How do I remove the spool and restring my trimmer?"
The spool is ******* on. There should be a Half Sphere-like object (Spool Retainer) on the bottom of the spool where the line goes. Twist counter clock-wise, or clockwise, depending on whether you have a Left-hand or Right-hand Trimmer.
If it is a duel line trimmer then:
1. Cut two separate pieces of string, about 7 ft. each.
2. Stick the end of the line in the hole on the inside of spool.
3. Wind clockwise onto spool,putting the line that is closest to the ground on first. Once you have wound this piece on, lock the last 4"-6" inches of line through one(1) of the 4 or 5 slits on spool.
4. Repeat process for second piece of line, putting it on the top side of the spool; locking the last few inches in the slot opposite the other locked in piece. (Remember, if you have a left-handed trimmer, the winding instructions will be just the opposite.)
5. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
6. Before you push the spool all the way on, pull the strings out of the locked position.
7. Place Half-Sphere-like object back on, twisting it clock-wise to tighten.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer a little longer than 7ft.
Here is a short video that explains 3 different types of heads:
http://i.fixya.netutube.png You-Tube video "OQauZqaEBUI&feature=player_embedded" placeholder
Good Luck with your project!
Jim
Key Words: Weed Eater, Trimmer Head, String, Chainsaw, Leaf Blower, Snow Bower, Pressure Washer, & Varnisized
on Oct 04, 2010 | Garden
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Need diagrams on how to wind line onto brushcutter spool model mtd pro bc230c-rs
Howdy Geoff,
There are basically 2 basic types of spool heads that are wound. This link will walk you through both types. Once you've successfully wound it once, it's not too difficult. http://community.homedepot.com/t5/What-s-New-in-our-Garden-Aisles/Replacement-String-Trimmer-Head/m-p/151/highlight/true#M4
Coach Dave
Oct 27, 2011 | Garden
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Possible Line-Feed Problem
The notches are there to hold the line in place while you place the spool back on the trimmer. If you look at the spool, you will find, on one end or the other, an arrow showing direction to wind the string. Follow the direction and when you get the spool full, place it into the notch. Leave about 6" sticking out and cut it off. If you have a two string spool, just wind the other string as you have done the first. When you have both spools full and the ends in the notches, place the spool on the trimmer. As you start the spool on, place the string (or strings) in the respective holes. As you seat the spool pull the string that is the farthest in until it comes out of the notch. Do the same with the other string. Seat the spool and try your handiwork. Good luck...Lee
May 28, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
String problem
Donna, take the spool that holds the string off. Look to see which wat the string is supposed to be wound onto the spool. If the string in on correctly, check to see if one or more of the turns of the string is overlaying itself. If there is overlap, clear it out by unwinding enough to unlap it. If the string is going the wrong way when you check it, remove and save the string from the spool, rewind it in the correct direction, put it back onto the machine and see if that corrects the problem. Woman or not, you are smart enough to ask, you are smart enough...Good luck...Lee
May 28, 2010 | Black & Decker 14" Grass Hog Xp...
Cub catet weed wacker needs new string and I don't know how to put the string on....
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
SPOOL
You have the string wound the wrong way. Wind in the other direction.
Jim
Jun 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
