Question about Refrigerators
Our GE side by side model GSS25SGRE is leaking water toward the front of the unit. We have pulled it out to see if it was condensation and that is not the problem. At times there is a lot of water that runs the grout lines of the floor and pools. This morning when I noticed the puddle, I opened the freezer door and saw that it is starting to accumulate alot of ice and this is a self defrosting unit. lastly, I noticed a sheet of ice at the bottom of the of the freezer compartment. What can be the problem as the refridge is only 4yrs old?
  • 110 Answers
Okay, my name is marclavoris, what happens is your refrigerator goes into defrost, the heaters comes on and melts the freon off the coils, the water goes down in the drain, which you will see on the freezer side at the very bottom of freezer, you may need to take off inside back panel to access the hole. it is clogged up with alot of debri, so when it is backed up, it overflows under your bottom tray, it then goes into defrost again and it pushes water on your floor. To solve problem, clear the drain in the freezer
Posted on Sep 12, 2009
  • 34 Answers
The drain coming from the freezer is plugged up. If tne drain goes out the back of the refrigerator try disconnecting it and blowing into the line towards the box then blow into drain towards bottom of box. This should do it.
Water leaking in floor from window unit
It needs to be slightly angled down towards outside for condensate to run off out side.
Jul 28, 2012 | GE AJES12DCC Thru-Wall/Window Air...
Leaking after auto defrost runs
When a refrigerator defrosts and also during normal operation there is water from melting ice or condensing on the evaporator which is supposed to end up in a pan or container under the refrigerator. This is probably full. I'm not sure how to access this on your model but there's either a bottom front cover which can be easily removed and the pan can slide out or through the access panel in the back towards the bottom. Hope this helps.
Sep 02, 2011 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My hampton bay air conditioner has started leaking badly after running it lfor a few hours, from the front right side
For window mount units, the unit must slope towards the outside. Water is a normal byproduct of refrigeration, like condensation on a glass of ice water.... Volume of water is not an issue, water dripping inside is. All water is intended to go outside, via unit slope.
Jun 28, 2011 | Hampton Bay Heating & Cooling
Water is leaking out the front of the unit
Water is a normal byproduct of the refrigeration process, Just like a glass of icewater has condensation on the outside of the glass.
The unit is designed to run the water outside. Check the slant of the unit, if it slants inside water will not exit outside..needs slight downward tip towards the outside.
Also check that the drain system is not plugged.
Nov 21, 2010 | GE AJHS08ASB Thru-Wall/Window Air...
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Nov 15, 2010 | Indesit IS70C Electric Dryer
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Zoneline PTAC Leaking
Hi Julie,
Is this a newly installed unit? The problem sounds like the sleeve is improperly installed. The sleeve should slope approximately 1/4 inch downward from inside to outside. This way the water will run to the back of the pan where it will be picked up by the slinger fan, or drain to the outside. Most likely this is the cause, not the styrofoam pan. If you need further info, you can contact me at greg.mcnary(at)airdistributors.com (replace (at) with @) and I can get you detailed installation instructions.
Greg McNary
Air Distributors Company, Inc.
Distributors of GE Zoneline PTAC Units and
McQuay PTAC Units
Aug 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Water leak
There is a problem with the condesation drain being plugged in the bottom of the unit. The water is supposed to drain onto a "condensation pan" under the unit where it typically evaporates without causing problems.
I believe that the solution was to pour bleech in the drain...
Aug 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire Model #FRS22WRC Side by Side leaking
Check the bottom of the freezer side is there a sheet of ice???
May 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
