Question about HP L1740 17" LCD Monitor
It will turn off on it's own, and I need to turn power to monitor on and off a few times to get it back on. Any thoughts?
    Problem Solver:
  • 9 Answers
Check the power supply,may be use another cable to check if it's that if not it won't turn on soon!!!!
Posted on Sep 13, 2009
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
HP Pavilion meets monitor
I would fathom a guess that the motherboard has been damaged, if it is the PS then you can see by taking it into a service center to have the output checked 3 v 5 v 12 volt good luck.
May 26, 2008 | HP w19 19" LCD Monitor
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
HP L1740 17" LCD Monitor Logo
117 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
