Question about Apple iPhone Smartphone
My iphone was working fine with my battery fully charged. I set it down and looked at my screen, it had green lines so I reset my phone and now it wont turn on.
  • 10 Answers
SOURCE: Iphone reset instructions don't work
u can try jailbreaking on ZIPHONE download will work as new
Posted on Mar 11, 2008
jws8118
  • 27 Answers
SOURCE: i phone non responsive wont charge or turn on
Based on your description, it sounds like this iPhone logic board isn't working properly. It could be related to the power management unit, or the battery could have simply become desoldered if you dropped the unit.
Another cause for this problem could be from water damage which may have fried the PMU chip. If this is the case and you're not experienced with BGA removal/replacing then you're best bet is probably to sell the unit AS IS for parts or repair on eBay, Craigslist, or you could sell it to me.
Hope this helps!
Posted on Jul 08, 2009
  • 32 Answers
SOURCE: my iphone 3g won't charge more than 10%....
it has corrosion in the charging hole or insde where the battery charging slots are
Posted on Jul 12, 2009
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
Posted on Jul 28, 2009
ag66339
  • 127 Answers
SOURCE: Just got my iphone. What does the little
Yeah, nothing is wrong.
Posted on Sep 22, 2009
Testimonial: "Thank you. Quick answer. Love this site. I have looked all over Apple site for answer to this & couldn't find it."
IPhone 4S shuts off randomly.
download itools get the latest one in the software there is system check crash report have a look on that it will tell you everything your phone is not doing, also when you install a new battery make sure the battery is flat, the screen should of come up with red line some batteries have charge in them and this can confuse the phone, another thing you can do is backup phone and do dfu setup, ios 8 sometimes has a problem and will need to be reinstalled new only do this in dfu mode, connect phone to pc etc and hold down the power button and home when the screen goes blank count to 6 seconds and then release the power button but hold down the home button for about 10 seconds or longer or until you hear the pc beep and install the dfu drivers. itunes will say that the phone needs updating do that, when finished don't do the setup , leave it for a few minutes then turn off phone leave off for 6 seconds then turn back on and continue with the setup it should be fine then, failing this and it still does this then the charging chip needs to be replaced, this is not a job for the layman need to be done professionally. hope this helps.
Mar 18, 2015 | Apple iPhone 4S
Loop in boot screen
hi, you can tap Settings > General > Reset > Erase all Content and Settings first, if it doesn't work, you can try iPhone Data Eraser, which can delete recent contracts permanently on iPhone and easy to use. It helps me a lot.
Nov 07, 2013 | Samsung Rugby SGH-a837 Cell Phone
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
My iPhone 4S won't charge when it's on
First go to Setting --> General --> Software Update and make sure you are at the latest version. There were some battery issues in previous releases. After that let your phone fully discharge (run down until it shuts off) and then charge it up to 100%. That should reset the battery. If neither one of those work then it is time to call the Genius Bar and have them take a look at your phone.
Oct 23, 2012 | Cell Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
Hi i get no service on my iphone
Have you tried to unlock the iPhone? This is a common problem if the iPhone is jailbroken or unlocked.
Kindly try the steps below:
* Go to Settings:General:Reset.
* Click Reset Network Settings
* Enter your passcode if you have created one.
* Click the red button: Reset Network Settings
* The iPhone will take a minute to shut down, then it will reboot.
- If these steps will not work, then follow the steps below:
1. Start with iphone with no service (jailbroken and unlocked)
2. Use iBrickr to load Launchctl GUI (Application -> Browse Application -> Launchctl GUI)
3. Open Launchctl GUI, look for the CommCenter line. If it is red - go to step 5. If it is black - proceed to the next step.
4. Select the CommCenter line, you will see a list of 3 options, select the unload -w, and press ok to confirm, the CommCenter should now be red in the list.
5. Fully restart your iPhone.
6. Open Launchctl GUI, look for the CommCenter line. It should be red if you did the above steps correctly.
7. Select the CommCenter line, you will see a list of 3 options, select the load -w, and press ok to confirm, the CommCenter should now be black in the list.
8. Press the home button. Your phone should now display 'searching' then display your network with full signal.
NOTE: Once your iPhone is working fine, open iBrickr again, go to applications, and delete the Launchctl GUI from your phone by clicking the red (-)minus buttons on the right of the screen.
Thank you and good luck!
Jun 13, 2010 | Apple iPhone 3G
I droped my iphone and screen turned white. what can i do to get it working again?
From Apple Support:
Display shows a white screen
  1. Turn iPhone off and turn it on again.
  2. If the iPhone will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple log or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
  3. If that doesn't work, try restoring the device.
Nov 29, 2009 | Apple iPhone Smartphone
Only charges... nothing else works on my Samsung
It should be fine to call when the phone is charging. It could be that the phone was "sleeping" as it charged and then the sudden energy draw of the phone call while it was charging screwed up the battery. I think you should take it to the shop.
Aug 23, 2009 | Samsung SGH-d807 Cellular Phone
Mar 09, 2008 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
43 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
