Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Input button doesnt work
The input button on the remote and the tv itself doesnt seem to be working?
4 Suggested Answers
freelance-au
  • 131 Answers
SOURCE: TV power will turn on and off but no other buttons operate.
This is more than likely down to your main AV board, Open the back and look at the board that has the arial and scart sockets on it, Take the part number of it and Google or Ebay for a replacement.
This will solve your problem.
Hope this helps
Posted on Mar 20, 2010
eagle338
  • 4889 Answers
SOURCE: TV comes on, then the
Seems like a problem with the main audio/video board. Does the screen come on and stay lit? Please provide this info so that I can confirm the problem and offer you an appropriate solution.
Sai.
Posted on Oct 05, 2010
gopakumarg43
  • 74136 Answers
SOURCE: The input and menu functions don't work, but all
Hello
Check the input connections first. Completely insert connection codes to the side panel jacks. If you do not, played back picture as well as selection will be abnormal.
Connect an external source to one of the INPUT terminals, and then press the INPUTS button to show the INPUT menu. Use the CURSOR PAD UP or DOWN to select the input of your choice. And then press the SELECT button or the CURSOR PAD RIGHT to confirm your choice.
Without any inpu signal, the input selection cannot be done. All the input chords must be conneted firmly and fully inserted to their respective sockets. OK
Posted on Jan 02, 2011
I have a lock on my panasonic lcd tv but my remote doesnt seem to be working so there is no way to input the code. What can i do?
You should be able to access this with the buttons on the Television itself. Using the volume +/- and the channel +/- to toggle through the menu options will get you where you need to go.
Oct 04, 2014 | Televison & Video
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Jul 01, 2014 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
My pioneer pro 1140hd elite remote is not functioning. A spare remote doesnt' work either so it must be the tv itself. How to fix?
If the remotes have both been tested (shops can check with a tester all buttons) you may have a remote receiver in the set that is bad--some the remote will not work or only works with remote very close to set.
Many digital cameras in a very dark room will react the same way when a remote is pointed at them and buttons pressed---a faint flash on the camera display.
Dec 03, 2012 | Televison & Video
I trying to connect a dvd to my tv and my input button is not working
When the input button on your remote is not working try using the AV button which can be found on your TV itself. The problem you are having is usualy as a result of the remote controller not being properly programmed if all other buttons are functioning.
May 18, 2011 | Fisher PC-6525 TV
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
No input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Dec 29, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
Remote Control not working
Heh, I got exactly the same problem 3 days ago. Question is, is it the remote or the unit itself?
Dec 30, 2007 | Samsung DVD-HR720 DVD Recorder
Buttons on TV or remote not working. Can only cycle through video input options.
It sounds as though the TVs in a demo mode. Has someone recently been over and was playing with the remote. If so go into the menu of the tV set and look for set up and demo mode. Turn off the demo mode. if this doesent help call i-866-427-3946 and talk to the customer service deptartment. Good Luck
Aug 09, 2006 | Apex Digital PF2025 20" TV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
