Question about HP 12c Calculator
Min eis an HP 11C. flashing 0.00
I replaced the batteries in my HP 11C (the original batteries, which lasted 25 years), and now the screen is flashing 000s. I put the old batteries back, and it did not solve the problem.
  • HP Master
  • 5,568 Answers
It may have latched up internally; I would try removing the batteries for at least a day, two would be better. The CMOS circuitry used is extremely high resistance (low power drain, evidenced by the long battery life) and there may be circuits which did not 'drain' down during the battery swap.
Posted on Sep 13, 2009
Testimonial: "I finally solved the problem by shorting the contacts of the batteries receptacle, with the batteries in. Thanks for the help."
  • 41 Answers
If the asterisk is flashing, the batteries you put in are not good either.
Testimonial: "Thank you forthe solution, It did not quite fix my problem, but I am getting closer. thanks a lot :-)"
Flashing asterick in left lower screen
That's the low battery indicator. Put in a fresh set of batteries and it will go away.
Mar 29, 2013 | HP 11c Business/scientific Calculator...
Screen 75% working correctly 25% screen black battery discharging within 35 min.
no there is no connection of battery with screen it should on full even for short time
the screen needs repair and battery needs replacement
Jan 18, 2013 | LG Xnote RD400
Small star flashing in lower left corner of display of HP 11C
Jun 08, 2012 | HP Office Equipment & Supplies
I have an HP rz1710 pocket pc. Can't seem to get battery fully charged. It gotten worse over time. After charging overnight or all day, it still shows low battery, then displays the hp IPAQ screen with...
If the unit will work while in the charger, it is most likely the battery has reached the end of its useful life. If this is the original battery, you are quite fortunate it has lasted this long and have taken good care of it because these batteries seldom last more than a two or three years before needing replacement.
Jan 02, 2011 | HP iPAQ RZ1710 Pocket PC
My EI Systems laptopwill charge the battery when on ac power but when i unplug from the mains it switchs off even though there is charge in the batteries
try leaving on overnight
to charge battery
else may need new ac charger
I know hp chargers only last 2 years of hard use
cheers
Sep 16, 2010 | Computers & Internet
MY HP 11C Calaculaltor has quit working. I changed the batteries and the screen only blinked a few times. How can I get this fixed? Where can I send this calculator to be repaired?
Try this first. Take out the batteries. Now take a paper clip and bend it into a "U" shape. In the well where the batteries go touch one end of the paper clip to one battery terminal while touching the other end of the paper clip to the other battery terminal. Hold it like this for 30 seconds or so. This effectively dumps any residual charge from the calculator. Now, reinstall the batteries and try turning it on. Assuming this doesn't work I'm afraid you're in the market for a new calculator. HP no longer repairs these so your best bet will be to replace it with the HP35s. The 11c can be found on ebay but they are extremely expensive. Good luck
Aug 02, 2010 | HP 12c Calculator
Battery time doesnt last long
Generally laptop batteries (Lithium-Ion) come in standard 6-cell and 12-cell configurations, lasting about 1.5 to 2 years before they begin to degrade in their charge capacity.
HP has issued 3 recalls in the last two years regarding laptop batteries, and you can check to see if your laptop qualifies for their replacement program under the recall at: http://bpr.hpordercenter.com/hbpr/
You can also shop Nextag for laptop batteries that are compatible with the dv600z, here are some search results: http://www.google.com/products?hl=en&q=laptop+battery+for+hp+dv6000z&um=1&ie=UTF-8&ei=EqgtSuvxF4_SNOvR7PcJ&sa=X&oi=product_result_group&resnum=1&ct=title
Lastly, if you purchased the laptop at Best Buy for instance, and you purchased the GSBTP (geek squad black tie protection) which is just their in-store warranty, they all come with a free battery replacement for the term of the warranty.
Hope this helps,
Joshua
Jun 08, 2009 | HP Pavilion dv6000z Notebook
Screen is flashing 0.00
I had the same problem with my HP 11C. The following solution worked for me.
1. Remove the battery cover.
2. With the batteries in place (i.e. DO NO REMOVE THEM), use a small piece of wire (I used a standard staple bent at one end), short the terminals FOR A BRIEF MOMENT between both ends of the set of batteries (the HP-11C has three). This means somehow inserting the staple such that the contacts in the batteries receptacle are shorted.
3. The flashing will stop. Then push the ON button until the calculator turns on. If it does not work the first time, remove the batteries and resinsert them.
4. You may have to repeat this procedure. I had to do it twice before my calculator worked again.
Apr 28, 2009 | HP 12c Calculator
Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
Oct 21, 2008 | Watches
HP 12c Calculator Logo
422 people viewed this question
Seeker5211
Seeker5211
