Question about Toshiba Satellite Pro L300-EZ1005V Notebook
There is no power lights even when plugged in i push the power button and nothing happenes but there is power at thew end of the power cord it was working then nothing can enyone help mt
  • Chip
    Chip May 11, 2010
    There may be power at the end but is it within specs for the power output the laptop needs to power on and run. Laptops are very sensitive to the power they receive and don't like to settle for anything else. If the power cord is indeed good, then I would seriously look at and test the DC jack, its solder points and the tension bar inside the jack that holds the plug in place also check that the center contact pin inside the jack has not been snapped off or displaced.
    Scholar:
  • 77 Answers
Sounds like the battery - try pulling the battery and powering on the laptop. Also, on occasion, even w/ a power light on the ac adapter, it still could be bad - try another one - you can pick one up from best buy, or another electronics store, and, if it works, you're good to go - if not, return it!
Hope this helps - good luck!
Posted on Sep 12, 2009
  • 674 Answers
DID YOU CHECK THE CHARGER? CHECK FIRST USE TESTER TO CHECK IT.. THEN IF THE SAME PROBLEM CHECK THE POWER BUTTON IF NOT THE DC CONNECTOR YOU NEED TO OPEN THE UNIT IF UNDER WARRANTY BRING TO THE WARRANTY DONT OPEN IT....
How to turn on
-Make sure power cord is plug very good into the printer.
-Make sure Plug to outlet and make sure there is power there.
Try again.
Good luck
Mai
Dec 05, 2017 | HP Computers & Internet
Black screen no fan sound but apparently getting power
for solve any type of error and issues dial toll free number +1(800)726-0294
and for more visit - 1 800 726 0294 Apple Support Number Mac Technical Support Help
Sep 10, 2017 | Apple PowerBook G4 Mac Notebook
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
Won't Power up. Plug in power cord and when you
i can't to the internet with the wire only wireless what is the problems
Oct 14, 2009 | Toshiba Satellite 2455-S305 Notebook
Vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Aug 05, 2009 | ViewSonic VG2230WM LCD Monitor
Computer seems totally dead
If the power cord is firmly plugged in - both ends, remove the battery. Does it turn on now? If so, replace battery.
gurutim
Mar 21, 2009 | Dell Dimension E510 PC Desktop
My Toshiba Satellite won't power up at all. No lights, nothing??
It happens all the time, laptops are known for power cords going bad. Because of the plugging un-plugging and twisting. This is a $25 solution after you have verified power from the wall and be sure the cables are secure throughout the power cord, this is 4 connections that needs to be checked.
To get your CD out of the drive this is simple if system won't power up. Get a paperclip and bend the end on the outside to a 90 degree angle. If you look on the CD/DVD there will be a pin hole, simply push the paperclip into the hole and when it stops, push harder and the drive should open manually.
Feb 15, 2009 | Toshiba Satellite A100-S8111TD Notebook
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Toshiba Satellite Pro L300-EZ1005V Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
