Question about Polaris 380 In Ground Pool Cleaner
Polaris is not sucking up pool debris, also the back up valve is not cycling, it's continously on and the wheel rotation is below 28rpm. I've checked the booster pump discharge valve and it's open, I've removed the blue restrictor and cleaned all the filters.
    Problem Solver:
  • 10 Answers
If the back-up valve is not cyceling this could definitely be the problem. Replace your Back Up-Valve. Also, check the hoses and swivels for leaks. .
Posted on Nov 05, 2009
  • 366 Answers
Check the impeller on the booster pump, it's possible some debris may have clogged it. You'll need to take the booster pump apart. If you don't feel comfortable doing this, call a service tech.
Posted on Sep 15, 2009
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM.
2. Adjust the thrust jet downward.
3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off.
4. Check for water inside the head float.
5. Empty the filter bag.
You can download the 3900 Manual from the Polaris site
http://www.polarispool.com/Pressure/Polaris-3900.aspx
It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
Jul 06, 2014 | Polaris 3900 Sport Pool Cleaner ()
Polaris 280 pool cleaner won't suck uP debris into bag
if pressure ok at wall and filter is clean check inside unit to see if hoses came off put on and zip tie
Mar 19, 2013 | Polaris 280 In - Ground Pool Cleaner with...
My Polaris 3900 that I bought today is not moving fast enough. There is no blue restrictor cap in the wall.
Check your filter, pump, and debris baskets for excessive waste that could decrease the pool cleaners water flow. Check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. Check your wheel RPM. If it is below 30, you will need to incease the water pressure. If you have an adjustable return valve, make sure it is open all the way. Also, make sure that your pump is working properly.
May 28, 2011 | Polaris 3900 Sport Pool Cleaner ()
My polaris 3900 moves across the pool with the front wheel of the bottom, the wheel on the 1 wheel side and the back wheel are on the bottom.
Check your wheel RPM. If the pool cleaners RPM is over 32, reduce the water flow so that the cleaner makes proper contact with the pool's surface. Verify the back-up valve is cycling. Lift the valve out of
the water and watch the jet. It should come on and go off. You might also need to adjust your thrust jet if it is causing the cleaner to lean too far to one side.
Oct 11, 2010 | Polaris 3900 Sport Pool Cleaner ()
Back-up valve is not working properly. Can I take
With these pool cleaners, if they are not backing up, there are several things that you could try. Lift the valve out of the water and watch the jet. It should be going on and off. If it is not, you will need to replace the back up valve. If it appears to be working properly, try adjusting your wheel RPM.
Jul 21, 2010 | Polaris 3900 Sport Pool Cleaner ()
Wheels are not turning. water is spraying from back up valve continually so not enough pressure to put machine into action
If the pool cleaner is not running properly (too slowly or not at all), you will want to check the following things. Make sure that your wheel RPM is not less than 30. If it is, you will need to adjust the wheel RPM to make the cleaner have enough power to move properly. First check your filter screen and the debris baskets in your pump, filter, and skimmer. They could have a blockage that is causing the loss of power. Next, if you have an adjustable valve on the cleaner line, open it completely so water can flow freely to the cleaner. If that does not work, remove the blue restrictor disk from the UWF. Also, check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. If you think that it is simply your backup valve that is malfunctioning, you might need to replace it. The backup valve kit is part number G52.
Jun 12, 2010 | Polaris 3900 Sport Pool Cleaner ()
Polaris vac doesnt reverse . which way is it supposd to be running, watr fow away from vac or towards vac?
When these pool cleaners are not reversing, there are several things that you need to check.
  1. Make sure that the back up valve is cycling (it should move in multiple directions).
  2. Check the wheel RPM and make sure that it is between 28-32.
  3. Make sure that the debris bag is empty.
  4. Check to see if the head float has water in it. If it does, replace it.
  5. Make sure that the feed hose is floating.
May 24, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Pacer does not run on INTEX pool pump, no pulsating action of diaphragm, pump sucking OK, Auto Weir Valve connected, pool 1,20m deep, round, 4,88m diameter
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Feb 03, 2010 | Zodiac Pacer Pool Cleaner
Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Aug 27, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris in pool cleaner back water single spout not water passing
Check your wheel RPM. With these automatic pool cleaners, you can manually adjust the RPM. Low RPM could be the cause of the problem. To check the RPM, first mark a single wheel side tire, Turn the pump on, hold the cleaner under water and count the wheel revolutions for one minute. If the RPM is less than 28, you might need to remove the blue restrictor disk from the UWF or adjust the gate valve on the booster pump. Also, this may sound simple, but make sure there is no debris lodged in the wheels/axles. Check your filter screen in your in-line filter and make sure that it is clear of debris. You will also want to check your hoses, connections, and swivel to make sure that there are no leaks.
May 31, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 380 In Ground Pool Cleaner Logo
577 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
