Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Rockford P5002 amp problem with thermal light and low voltage
I have a Rockford P5002 that was in a different vehicle and am now putting in a 95 Subaru Impreza. All connections are new (bought a kit from Crutchfield) but when it powers on, the "thermal" light comes on. It was just turned on, so doubt it's overheating. I followed another post and checked the wiring coming in with a multimeter. I got about 7 volts for both the B+ and the remote turn on. I checked my battery straight and it's 12 when not on and up to 13ish when engine is running, but even then, just over 7 on the amp. That's a big difference. No matter what I check, can't seem to get amp off thermal. Any ideas? Thanks!
  • 655 Answers
Hello rbenwalker,
The voltage drop may not be in the actual power wire itself. The same reading on both the B+ and remote terminal probably points to a bad or high resistance ground. Try a different ground point or make sure there isn't any corrosion, paint or anything else preventing metal to metal contact.
Hope this helps.
Posted on Sep 13, 2009
Testimonial: "Thank you! Ended up changing the ground and works like a charm, now. Didn't even think that might be the problem."
  • Landon Elwood Oct 25, 2011
    this is wisconsinkid81@yahoo i recently diconnected my P5002 rockford fosgate amp for about 6 months and recently got a new sub and went to hook it back up and the power light on the amp comes on but no sound comes out of the amp?? and this is very baffeling to me! I have never delt with a problem like this and I am at a lose to why this is happening if u can please help!! my e-mail is wisconsinkid81@yahoo.com thanks!
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Rockford P5002 not getting enough power
7 volts will not be sufficient for the amp either for power or remote. Also check to make sure you speakers wires are not crossed. If its goin it to protect mode immediately the amp is detecting a fault and is not turning on.
The thermal and power lights are on soon as i hook the amp up to the power
check your connections, this usually indicates that you have a short circuit but also make sure that your earth strap is securely fastened to a clean metal fixing.this could well be the cause of your problem.
May 05, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Thermal light goes away when ground added
Doesn't sound like anything is wrong. If the thermal light is on before you have the ground hooked up then the amp is probably getting a small amount of electrical ground from the shielding on the RCAs or its mounting to the chassis of the vehicle allowing the amp to "barely turn on" (not enough ground). I can imagine this would make the amp think something is wrong (ie: thermal light) . May I suggest that you do not try to turn any amplifier on without ALL appropriate wires connected correctly.
Mar 01, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Sep 12, 2009 | MA Audio HK4000D Car Audio Amplifier
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Apr 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
If you hook up speaker and hear a pop you more then likely have 1 ch blown causing dc on output. You can use multimeter and measure voltage for both ch,s between positive and negative terminals..One channel will more then likely measure 0v and the other one which is defective wll measure a dc voltage. These amps have what are called mehsa bars which output transistors are mounted to. Need to contact Rockford fosgate 800-669-9899 to arrange for flat rate repair.
Jan 16, 2008 | Car Audio & Video
Rockfordsfostgate amp
Is the blue light lit?
Are any of the other lights lit?
Have you confirmed that the speaker isn't blown?
Jan 04, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Amp - When grounded, both power and thermal lights go off
You shouldn't have the power wire connected to the amp without having the amp's ground terminal connected to a good ground. With some amps, it will damage the head unit.
Does the amp power up normally if you connect power and ground and then apply remote voltage (turn the head unit on)?
Dec 18, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
610 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
