Question about NEC ND-3550A-KIT DVD±RW Burner
Stops burning at 99%
Hi, the problem I am having is the following: no matter what software I use, all of a sudden I cant burn DVD's no more. When using Nero the program stops at 99% and restarts, the disc is lost. Like I said I have used other software, to no avail either. This is getting hopeless, I have lost quite a few discs already. I tried updating the firmware I downloaded from NEC website, (2.1) but that tells me: target is not found correctly. And stops there...
As far as I can see there is no good explanation on what to do next on the NEC website.
Windows tells me that the drive is working fine, has the latests driver etc etc. This drive reads fine, btw. The problem is with the burning, that all of a sudden and out of the blue didn't work anymore...
All help is appreciated!
3 Suggested Answers
SOURCE: NEC ND-6500A Cant burn DVD-R
hi all. good to find other people with the same problem. I have tryed now oweer 9 houers without getting no way
Posted on Jun 16, 2008
  • 119 Answers
SOURCE: NEC ND-3550A won't read discs
try this Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the Upper/lower Filters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value? The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
do same thing to erase the lower filter then restart your computer
Posted on Jul 24, 2008
  • 519 Answers
SOURCE: NEC DVD_RW ND-2510A (Burning problem )
I recommend you have a trial of Video Download Studio to help you with this.
Download film from any film sharing website, and then convert the film format to suit for any portable device.
Get a free trial of Video Download Studio from
Hope it can help you more or less!
Posted on Nov 16, 2010
0 characters
1 Points
DVD wont burn with dvd maker gets to 99% then stops
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
Change Windows DVD Maker DVD-Video settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq CD & DVD Burners
I have always been using Nero burn software with my LG GSA-2166D DVD RW. Now I bought Nero Multimedia Suite 10. No any writing process has been successful. I have since yesterday spoiled 10 DVD's....
speed of source data is too slow = the hard disk cannot deliver the data fast enough and the burning process stops; this is a sign of a severely fragmented file system and very charged background processes: defragment your hard disk, stop using other programs when burning a disk and use 8X as a recording speed.
 Track Following Error = the laser head in the burner is no longer capable of following the track it has itself burned - the lens is dirty, clean it.
Jun 12, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
I want to know if a sata dvd writer can burn dvd
Are you kidding hehehehe it's a joke, Of course it can burn, if your unit is a DVD writer it can burn a DVD no matter if it is a IDE or SATA type of cable connector. Be sure that you will have a burner software (like Nero, power to go, etc.) installed in your computer.
Sep 02, 2009 | Samsung SpeedPlus DVD-Writer 20x, Black ...
Trouble transferring video to DVD
have you uninstall and reinstall your burnning software? change your DVD-R brand, slow down your burnning speed, update your mainboard chipset
may help
Jul 21, 2008 | JVC CD & DVD Burners
Samsun SH-s202N & Nec Rewriters will not burn DVDs over past fews
Yes, SP3 has known to cause this issue. Let me check further for you..
Jun 01, 2008 | Samsung TS-H552U DVD±RW Dual Layer...
Device stopped to read any disc
for EnzoMolinari
u r drive is having an hardware problem just contact nearby service center
Apr 27, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Will not burn anything, or read anything
try this
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
Mar 03, 2008 | CD & DVD Burners
Burning video to DVD
hi there
have you tried using another software? software that stops or cancels within you trying to use it only indicates that there might be conflicts with other softwares installed on your computer.
i suggest you try installing another dvd burning software.
hope this helps.
Feb 20, 2008 | CD & DVD Burners
I figured out what was causing the problem with my NEC 6500A on my Dell laptop: The Sony Picture Motion Browser software that I was using to burn DVD's is only compatible up to Service Pack 2 of Windows XP. The day after I installed Service Pack 3, the software stopped burning DVD's. So I uninstalled Service Pack 3, rebooted, unistalled the Sony PMB software, rebooted and re-installed the Sony PMB software and I can now burn DVD's again. So check whether the software you're burning your DVD's with is compatible with whatever version of your operating system you're operating with. Hope this helps someone else!
Dec 16, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
Freecom Classic DVD±RW 8432 Burner
Hi ,
Make sure you still have the software stored on your machine or on cd .
Please delete software and go to this site :
Follow instructions to reinstall software .
If same issue remains , try to remember what changes you eventually made to your machine just before problem happened and delete the changes to see what happens .
You can also try to restore your system to an earlier date , provided this is possible with Apple .
Hope this helps .
Thank you for visiting FixYa .
Jan 11, 2007 | Freecom Classic (22095) (22095)...
NEC ND-3550A-KIT DVD±RW Burner Logo
70 people viewed this question
Top NEC CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Michael Thomas
Michael Thomas
Are you a NEC CD and DVD Burner Expert? Answer questions, earn points and help others
