Question about Sony Ericsson Walkman W810i Cellular Phone
Same problem how do you create mms account?
To create acount
there is no need to create account for sending any type of mms through your cellphone.
you may directly send mms through message menu.
thank you.
Jan 25, 2013 | Nokia 6500 Slide Cellular Phone
Tip
Restore WAP, 3G, MMS Settings | Sony Ericsson Phones
Many people are having problems configuring their phones after de-branding or after flashing it. Usually after de-branding your phone you lose all the WAP, Internet, MMS settings from the phone. And you won't be able to send MMS or browse Internet.
For MMS and WAP to function properly, you should first create Data Accounts in Phone Settings and Then create Internet Profile and MMS profiles which make use of the Data Account. For manually creating these accounts and profiles you will need a lot of technical information from your CellPhone Service Provider. You will need to know the APN, Proxy Address if any, Username and password settings. Hence the idea of manually setting up is not recommended, unless you have spare time to figure out things.
You can directly download WAP and MMS settings for your phone from local Sony Ericsson Website. Visit SonyEricsson.com. In support section specific to your country, you will find links on how to configure Internet and MMS. Visit those links, You will be asked about phone model and operator name ( like Vodafone, Airtel in list), Select your operator and provide your cell phone number. You will be given a authorization code, and in a few minutes Sony Ericsson will send you the Internet/MMS settings directly to your phone. Enter the authorization code in your phone. And MMS, WAP, 3G and Internet settings will be installed correctly. All operator based services should then work fine.
Thank you for using FixYa!, Keep visiting..
Concerned, Nooh.
on Jan 23, 2011 | Cell Phones
What is the gprs/mms setting for sony ericsson X8? my network provider is globe philippines. i went to their customer service but even the representatives there can't help me with my problem.
Just follow this Guidelines
GPRS SETTINGS
1. Go to Menu>Choose Settings>Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Browser, Slect Options and click Internet Settings
6. Add New Profile
Connect Using: MyGlobe GPRS
IP ADDRESS: 203.177.042.214
ADVANCED
Chg. Homepage: MyGlobe GPRS
Address: http://www.globe.com.ph/globe.asp
Save Profile
MyGlobe Internet Settings
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
5. Go to Messages>Picture Messages>Option>Internet Profile
6. Create New Profile
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
9. Save Settings
10. Go to Messages>Picture Messages >Options
11. Edit Message Server
http://192.40.100.22:100.21/mmsc
12. From Message Settings, make your Internet Profile: MyGlobe MMS
Hope it helps...
Jul 15, 2011 | Sony Ericsson XPERIA X8 Cell Phone
How to open the GPRS of chinaphone
creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially those phones supported by Globe and Smart, no need to activate your SIM. This is also valid for postpaid users since SIM cards are pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and GPRS, you need to activate your SIM before you can use MMS and GPRS services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this number is still valid). No need to download the configuration for Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I tried to call Globe Customer Service but they cannot activate your SIM manually on their system and the only way to activate it is by downloading the configuration thru text or by asking them to send the configuration. But since China Phones are not yet supported by any Service Provider, what you can do is to active MMS and GPRS using another phone. Monitor until your SIM is activated then transfer your SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE p900. I?ve never tried this but if this really works, well and good for China Phone fanatics.
Jul 08, 2010 | Nokia 6300 Cellular Phone
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
4. Save Account
5. Go to Internet Settings
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
12. Save Changes
3. Create New Account. GPRS / PS Data
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Jun 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
MMS wont work, there is no data account on(server
create a new connection and name it what u will
the connection ip for tmobile is 216.155.165.050
APN : wap.voicestream.com server : wap.voicestream.com data mode : connection oriented you only have to set up server one.......and can set the timeout to 90 secs ..... power your phone off then back on after setting this connection as default oh yeah, go to settings, network, account to create a new one
Jul 28, 2009 | Dual Cell Phones
Gprs, mms and inet seetings for se c510
GPRS Settings:
1. Go to Menu>Choose Settings. Press Left Navigation Key to go to Connectivity. Scroll Down and click Internet Settings
2. Choose Connect Using: and Add Data accounts. Enter the following parameters
Account type: PS data
3. Save Account
4. Choose Options Menu by clicking the left soft key.
5. Choose Edit. Leave all the settings as default except Proxy Settings.
6. Go to Proxy Settings and Edit.
Proxy: On
Same for all servers: Off
Proxy servers: Multiple
7. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Proxy address: 203.177.42.214
Port: 8080
8. Press Back four times
9. Press Select to choose myGlobe CONNECT as default account.
10. Press Save.
11. Go to Main Menu> Internet>Options>Advance. Press Left Navigation Key to go to Connectivity.
Connect using: MyGlobe CONNECT
Default Homepage
12. Press Save
MMS:
1. Go to Menu>Messaging>Settings>Picture message
2. Go to MMS profile
3. Create New Profile.
MMS profile name: MyGlobe MMS
Message server: http://192.40.100.22:10021/mmsc
4. Choose Connect using: and Edit.
5. Choose Options Menu by clicking the left soft key.
6. Create New and enter the following parameters
7. Save Account
8. Choose Options Menu by clicking the left soft key.
9. Select Edit. Go to Proxy Settings and Edit.
Proxy: On
10. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Port: 8080
11. Press back four times
Press Save. Select MyGlobe MMS as new MMS profile
Jul 14, 2009 | Lands Phones
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
3. Open GPRS.
Auth. Type: Normal
Auth. Type: Normal
APN: mms
Auth. Type: Normal
APN: smart1
Auth. Type: Normal
2. Open WAP.
3. Open Settings.
Proxy Port: 8080
Proxy Port: 8080
1. Open Messages.
2. Open MMS.
Proxy Port: 8080
Proxy Port: 8080
May 06, 2009 | Nokia 5310 Cellular Phone
How, where can i get the i.p adress of my china phone n5310,
hi dave, you can try visitiing smart centers, they can surely help you with that.
Feb 15, 2009 | Nokia Cell Phones
Sony Ericsson Walkman W810i Cellular Phone Logo
16 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
