Question about MA Audio HK4000D Car Audio Amplifier
Rockford P5002 not getting enough power
I have a Rockford P5002 that was in a different vehicle and am now putting in a 95 Subaru Impreza. All connections are new (bought a kit from Crutchfield) but when it powers on, the "thermal" light comes on. It was just turned on, so doubt it's overheating. I followed another post and checked the wiring coming in with a multimeter. I got about 7 volts for both the B+ and the remote turn on. I checked my battery straight and it's 12 when not on and up to 13ish when engine is running, but even then, just over 7 on the amp. That's a big difference. No matter what I check, can't seem to get amp off thermal. Any ideas? Thanks!
    Guru:
  • 1,326 Answers
7 volts will not be sufficient for the amp either for power or remote. Also check to make sure you speakers wires are not crossed. If its goin it to protect mode immediately the amp is detecting a fault and is not turning on.
Posted on Sep 13, 2009
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford P5002 amp problem with thermal light and low voltage
Hello rbenwalker,
The voltage drop may not be in the actual power wire itself. The same reading on both the B+ and remote terminal probably points to a bad or high resistance ground. Try a different ground point or make sure there isn't any corrosion, paint or anything else preventing metal to metal contact.
Hope this helps.
Sep 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I need to find output transistors for a Rockford amp
Call rockfor fosgate and ask if they sell component parts to public, if not, ask who the their component manufacturer is, maybe you can get it directly from them.
Sep 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Tail lights and marker lights stay on
On my 2004 Impreza ther is a switch on top of steering column that turns those lights on all the time. Look for that switch.
Dec 10, 2008 | 2005 Subaru Impreza
Looking at a '95 Subaru Impreza LX
you guessed it right at 60,000 miles there is a major service due. The service consists of flushing all fluids, tire rotation, and a complete tune up with a top end clean, and a fuel injection clean. Apptox $350 to $400.
Nov 10, 2008 | 1995 Subaru Impreza
Will parts for a 95 subaru impreza 1.8 work on my 93 1.8
as long as you use the entire assembly, I have run across this with my brothers car, the trans axle was bad, he tied to use just the parts he needed, they were different design, so he ended up changing out the whole unit.
Jun 19, 2008 | 1993 Subaru Impreza
P5002 Problem
The schematic is available from Rockford.
It's possible that the outputs have blown. They generally short from the center leg to the third leg when they fail.
Unless you have experience working with the MEHSA insulators, you may want to buy the entire MEHSA strip from Rockford. You can replace the transistors on the insulators but you have to use a torch to heat the strips.
Nov 18, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
100 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
