Question about Electrical Supplies
Clone honda 6.5HP engine
I' need to know how I must calibrate the valves of a honda clone 6.5 hp 4-strokes.
Can anyone help me?
I live in Argentina, south America and need a tecnical manual of that engines.
It has 196 cc. and 6.5 hp.
It's from China
Thank you
  • 211 Answers
Hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
Posted on Sep 16, 2009
You'll find your answer here... The 5.5, 9 & 13 HP have the same clearances. My 6.5 Hp Honda Clone 3800W Wenling Jengfeng 5WJFS.1961GA runs fine off the same settings.
http://www.princessauto.com/hlr-system/Documents/47/477/4770/4770426_manual.pdf
Posted on Jan 10, 2013
    Problem Solver:
  • 12 Answers
The specs for the Honda 6.5 hp is 0.004 on both intake and exhaust valves. Also, the piston should be about 1/4 turn before top dead center on the compression stroke.
Posted on Nov 03, 2010
1996 Honda passport lx/DX 4 door 4wd red 5 speed w/ izzuzu 32valve v6
honda/rodeo clone with the correct motor fitted
what was the question ?
The Isuzu V engine is a family of all-aluminum 75° V6 gasoline engines produced by Isuzu . ... This engine featured 175 hp from 1993-1995 and 190 hp from 1996-1997. ... in Japan, and in North America as Isuzu Rodeo and the Honda Passport . .... engine was Isuzu's newly developed 4.2L, DOHC 32 valve V8 engine, and ...
Apr 22, 2017 | Honda Cars & Trucks
What are the valve lash specs for 2007 Honda Accord V6?
There is a specific procedure for setting valve clearance . I highly recommend getting a repair manual for the correct specs & procedure. The engine must be at TDC with the #1 cylinder on the compression stroke , that will allow you to adjust ONLY certain valves , then you have to turn the engine one turn to TDC again only now #1 will be on the exhaust stroke & the rest of the valves can be adjusted . it's important that you know the difference between the two !
Jan 08, 2015 | Honda Cars & Trucks
Do i mix oil in the gas on the coleman powermate 8750 honda 13 hp?
Hi, no you don't. It is a four stroke engine and uses engine oil in the sump only. Regards Phil.
Jul 28, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
Fuel mixture fOr cb100 are thet two stroke?
The Honda CB100 has a 4-stroke, single cylinder engine. It runs on straight gasoline, so you don't need to add any 2-stroke premix when you fuel up. On the other hand, you'll probably want to check your valve clearances about every 1500 miles or so--these little engines get run pretty hard, and valves out of adjustment will rob you of desperately needed power. With only 1 cylinder and 2 valves, this doesn't take long at all, once you've done the job a few times.
May 20, 2011 | 1973 Honda CB 100
2001 ultra classic tire size
Specifications: Engine Type: 1449 cc, 4-Stroke, Air Cooled, V-Twin
Engine Bore and Stroke: 95.3 mm x 101.6 mm
Valves 2 valves/cylinder
Claimed Horsepower: 67 hp (50 kW) @ 5200 rpm
Maximum Torque: 110 Nm (81.1 ft. lbs) @ 3100 rpm
Transmission type: 5 speed
Final Drive: Belt
Tire - Front: 130/90-16
Tire - Rear: 130/90-16
Brakes - Front: dual 292 mm discs with 4-piston calipers
Brakes - Rear: single 292 mm disc with 4-piston calipers
Sizes can vary depending on what has been done to the bike.
Ride safe and loud pipes save lives.
Dec 14, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
How often to rebuld a 450 four stroke compared to a 250 two stroke?
a biger 4 stroke engine will out live a smaller 2 stroke engine many times over,,, but it all depends on how well its serviced and how its driven,,,belting the guts out of it all day and its not going to live very long
Feb 11, 2010 | 2004 Honda CRF 450 R
Need to know how to time honda harmony tiller
well
heres your 4 strokes
1 intake down
2 compress up
3 power stroke down
4 exhaust up
if you start with you start with the piston just a couple of degrees past TDC (top dead center) so that it has started its return down
now set the valves so they are closed:
if you have an adjustable valve clearance's then your clearances should be noticeable like 10 thousands ( you should be able to move the lifter ( rocker arm ) and it will be loose up and down
with the spark plug still out; so you can see the piston coming to TDC and passing it to come down
turn the flywheel and watch the strokes and the condition of the valves
1 just past tdc, the intake valve opens and the piston goes down for the intake stroke
2. jst as the piston comes around BDC the intake valve should close and return to tdc with all valves closed ( the compression stroke )
3 just past TDC the ignition will fire and the piston will return down with both valves closed( the power stroke)
4 just past BDC the exhaust valve opend , the piston travels up and completes the exgaust stroke.
and after completing the exhause stroke and arriving at tdc the intake valve opens and you start over again 1,2,3,4
Apr 14, 2009 | Honda Garden
Installing push rod guide
I have worked on many gx160 engines and have found that the most economical way to repair an engine with worn valves/guides is to replace the complete head with a clone usually available on ebay for around 60 bucks or so. A honda gx runs perfect with a new clone head. To repair the head properly you need special tools to cut/shape re-seat etc. Then when you consider the cost of honda parts and the chance of making an error, well even the best small engine mechanics make bad calls. However on the other hand, there is great pleasure in rebuilding an engine that has given you great service. Small engine parts/supply outlets like Rotary inc. sell valve guide cutter kit that comes with instructions. You should also use new valves and cut the valve seats.(another kit) If all you want is a great running motor, consider the clone head. Good Luck on your project.
Jan 29, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Electrical Supplies Logo
2,058 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
