Question about Gigabyte Computers & Internet
Unable to power up System
Having similiar problems...I just bought a new Coolmaster case, GA_MA770-UD3 Motherboard, AMD Phenom II X3 Processor, new Antec 500W power supply, 4GB OCZ Memory and I can't get the machine to power up. I have built several machines in the past, but I am stumped on this one. I am wondering if the F_PANEL connections are accurate in the manual, but I have tried just about every configuration. The made sure the power supply is in the I postion and not the O. I also tried several outlets to confirm that power is coming from the wall. Need some help!
    Scholar:
  • 77 Answers
Will the desktop even post? I would remove each component, one at a time, and try powering the pc up each time - i've seen issues w/ a processor/mobo being incompatible, causing the pc to not power up - also have seen issues where the power supply isn't strong enough to power the system...especially w/ the coolmaster cases. Do you have a 1000w supply to try to swap in the machine?
So, first pull the memory - try to get it to post - then h/d, etc.
Good luck - hope this helps!
Posted on Sep 12, 2009
How do I upgrade an AMD Phenom II x3 710
I suspect you mean the Motherboard that has the AMD Phenom II x3 710.
If so then find specifications on that motherboard to see what better, faster? CPU is compatible with it.
4th Core is Disabled by AMD and you need to know how to enable it?
Maybe this can help.
Overclocking Phenom II x3 710 2 6GHz to 3 5GHz unlocking 4th core
Hope it helps
Oct 11, 2014 | AMD Computers & Internet
THIS MAINBOARD SUPPORT THIS PROSESSOR Phenom II X4 920 (2.8GHz, 125W, 2MB total dedicated L2 cache, 6MB L3
Motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=943&DetailName=Feature&MenuID=1&LanID=0
Processor Support (CPU Support),
AMD Phenom II X4 model 920, uses .0875 to 1.425 Volts, (DC),
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
That is the average voltage range for the AMD Phenom II X 4 processor.
Look back at the AMD Phenom chart again on Wikipedia, and look especially at the voltage range for the 900e to the 945.
Now look at the ECS CPU Support page again, and you'll see your motherboard supports Phenom II X4 processors from 900e to 945.
Since the 910e and the 925 are supported, I know the technology of the 920 is supported.
The Core architecture and nanometer technology it is based on, is supported.
No BIOS update may be needed.
Yes is the answer.
For additional questions please post in a Comment.
Regards,
joecoolvette
[NOTE*
That processor can use up to 125 watts of power. You need a decent Power Supply.
That processor also gets H-O-T!
Make sure it has a GOOD cooling system, and the computer case inside, and the Power Supply, inside, are kept clean ]
Aug 04, 2012 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
HI ! I bought a new AMD phenom quad-core 9750 2.40ghz processor and Gigabyte motherboard. I m unable to install Windows and the system automatically shuts down every 20 min and sometimes runs for more...
This processor need better cooling system as it is powerful it need more power so I suggest you to upgrade your Power Supply and buy more efficient processor fan cooler. Also you should check if processor is properly installed on motherboard and there should be some special thermal grease between processor and motherboard (http://en.wikipedia.org/wiki/Thermal_grease) for better thermal conductivity
Oct 25, 2010 | AMD Phenom X4 9750 Quad Core Processor...
Can the gigabyte ga-ma74gms-2h motherboard support any of the new icore cpu's
For what I have read on this MOBO, it is AMD processor only board so it will not support Intel in any way. Below is the list of processors the board supports....alll AMD
Athlon 64 X2 , Sempron , Phenom , Phenom X3 , Athlon 64 , Phenom X4 , Athlon 64 FX
Aug 01, 2010 | Gigabyte Computers & Internet
NEED HELP 8(. GAMING CASE
case sounds fine, a little iffy on the power supply.
Feb 20, 2010 | Computers & Internet
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Suitablle motherboard for AMD X3 8450 X3 7850 CPU
Sorry that I entered without an answer to your problem. I am not that familiar with the AMD X3.
Jun 21, 2009 | Computers & Internet
AMD Phenom II x4 920 processor works with a GA-MA790X-UD4P
Yes, that Gigabyte motherboard does support the Phenom II X4, for additional CPUs it supports check out the following website on the specifications tab:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387&Tpk=GA-MA790X-UD4P
Mar 12, 2009 | Gigabyte Computers & Internet
Open Questions:
Computers & Internet Logo
94 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
