Question about Marantz SR-18EX Receiver
I have the SR6200 and I am finding I have to really crank the volume to get the same sound that I used to have on a lower volume setting----I have not changed anything---any ideas? This is occuring with the TV, DVD and tuner---
  • 69 Answers
Sounds like you have an issue with the cables/leads from the receiver to the other equipment? try buying a new set of cables and/or check that the pins/plugs are in correctly, they may have been disturbed? wiggle the plugs on the leads at the back of the receiver whilst it is playing music/tv and do the same to the rear of the dvd/tv/cable unit. if you get intermittent increase in the volume it is likely that the cable has a break in one of them? good luck
Posted on Sep 13, 2009
Volume low when i transfer to my pc?
I find everything I play on my PC is at a lower volume than when played on another system, despite everything being at max. Dunno how to overcome that
Apr 03, 2015 | Fostex MR8-MKII - 8 -Rack Portable Compact...
How do I lower sound on an incoming call
Once you take the call hit the button that lowers the volume. It should lower to ur desired setting. You could also do this from the settings. Got to ur settings. Go to volume or sound. Then go to call volume.this will set it as ur desired item call volume.
Sep 27, 2014 | HTC Desire Cell Phone
I have a sony MP# player, same range as listed but the 8GB model. I can only turn volume up to 16 before it starts distorting and giving a really bad and weak signal though the headset, when the stereo...
Headphones are not designed to have the volume levels run at maximum. At this level the sounds from the headphones will distort.
Speakers have a much larger voice coil and therefore will not distort at higher volume levels.
Also when the speakers are connected to the MP3 player the sound level may appear lower because speakers require more energy to drive (produce sounds). In this case you need to connect powered (amplified) speakers to the MP3 player.
Mar 10, 2011 | Sony Network Walkman NWZ-S545 Digital...
How do i turn the volume on
On the Setup Menu there is a "Sound Settings" item. Here you can turn on/off the button sound, control the shutter sound, and the volume of the shutter sound and the startup sound.
During movie and audio playback, you can adjust the volume by pressing the zoom buttons. W to lower, T to raise.
Bear in mind that the CoolPix wasn't really designed as a video camera or an audio recorder. It only has a small, not very sensitive microphone, so you're not going to get much sound from any distance.
Jan 20, 2010 | Nikon COOLPIX S200 Digital Camera
I have a p168c. when i call out, the receiver can't hear me well.
Try lowering your in call volume the next time you are having a conversation with someone using the keys on the right side of the flip.
Jun 02, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Nov 07, 2008 | Logitech X-220 Computer Speakers
Lenovo laptop with terrible beep-sound when power-supply are plugged in- and out
If you're using to Lenovo Ideapad U330 click on the volume setting and go to options: properties.
Select PC Beep and then adjust the volume to your desired level or mute completely
May 14, 2008 | Lenovo 3000 V100 Notebook
The sound just stops dead
I have the exact same problem. Try to crank up the volume from your stereo/receiver and lower the volume in the headphones. I think that the headphones goes into standby mode if the volume is to low. Works for me (for two days, so its not really a fact yet ;-) )
Feb 24, 2008 | Sony MDR-RF970RK Headphones
Low volume bass
You need to look got the amp for the sub if there is not one there is notting you can do. If there is one then just turn up the gain on the amp.
If not there are some times the gain is on the radio in a setting and the only way to find that is to look in the user manuil.
Oct 15, 2007 | Kicker 05C104 Car Subwoofer
Marantz SR-18EX Receiver Logo
140 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
