Question about Samsung Blackjack SGH-I607 Smartphone
My blackjack screen is badly scratched. (I think it's just the clear plastic outer cover.) Is it possible to replace this part? Is it a do it yourself job?
  • 854 Answers
Watch this
http://www.youtube.com/watch?v=TvpWPrHRNK8
Posted on Sep 12, 2009
Go my angelcare parent unit with video has crack in it, is it possible to replace the screen?
if the crack is only in the outter cover screen , a quick hack is to buy a piece of that clear plastic that goes over ID's and documents that's sticky on one side , it will press down onto the screen and keep it tight sealed , plus if it gets scratched it rips right off for a new piece
Feb 24, 2016 | Baby Gear
Scratch on sanyo flat screen tv
The overlay or outer screen on any LCD or Plasma is bonded to and cannot be removed/replaced short of replacing the entire Panel or display unit which needless to say costs more than the set did when new.
If its an older projection set the outer clear screen may be available depending on brand and model number.
Apr 18, 2012 | Sanyo Televison & Video
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
What you need is a replacement "lens". You can find them on amazon and ebay for anywhere between $6 and $20. Some places will also send the replacement instructions, and some won't. You can replace it yourself if you have the right torx screw drivers.
If you can't find replacement instructions, you can buy a copy of the service manual from here for a bout $7.00
http://www.tradebit.com/filedetail.php/8997596-samsung-sgh-i607-blackjack-service-manual-
Sep 12, 2009 | Samsung BlackJack II Smartphone
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Nintendo ds lite touch screen protective outer layer(plastic)
you must send it in to Nintendo, for a new touch screen or take it to your nearest GameStop video store.
Dec 18, 2007 | Nintendo DS Lite Console
Garmin GPSmap 76Cx cracked screen
buy a broken one on ebay for parts and replace the outer cover. the same happened to me w/ a similar unit. good luck.
Nov 06, 2007 | GPS
Samsung Blackjack SGH-I607 Smartphone Logo
16 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
