Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
The bulb primer is not sucking gas into it's chamber in order to prime start the blower
  • 279 Answers
If you are not getting any fuel it should be either the filter plugged or the primer bulb leaking air. It could also be the fuel line. Give all of them a good look. ...Lee
Posted on Sep 14, 2009
  • markwhemm
    markwhemm May 11, 2012
    I took off the primer bulb and a spring fell out. Whre does it go
  • markwhemm
My leaf blower will not prime there is no gas coming in the primer bulb
check to see if your gas filter is stuck inside the gas tank... it should sit loose at the end of the fuel pick- tube
Sep 14, 2014 | Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Primer bulb does not work
if you have gas in the primer bulb its working. gas is sucked from tank to carb , out return tube to primer bulb and back to the tank from the primer bulb. most likely dirt in carb or hard diaphram not opening needle valve allowing fuel to be sent. carb kits are around 12 bucks . but carbs for troybilts are usually only 20 bucks. I would just replace the whole carb if the case. if the bulb stayed empty I would look for broken fuel line in the tank that holds the fuel filter. they rot and break off within a year or two.
Apr 20, 2012 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
Nov 18, 2011 | Homelite Carburetor Trimmer Blower...
Toro model number 200065 won't start. New gas, new spark plug, cleaned air filter. Doesn't feel like fuel is in the primer bulb when I prime it.
some toro primer bulbs don't fill up with fuel but blow air into a chamber in the carb that has fuel in it so when you press the bulb, the air sprays fuel into the carb ( just a little) So since it won't start, the bulb probably has a very small crack in it. replace it and then try it.
Aug 10, 2010 | Toro Lawn Mower With Toro Power Tools
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
1,348 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
