Haier LCD 32 turn on no picture and after 2 minutes picture one half is blured and other half is ok.
headstrong
  • 233 Answers
SOURCE: 23 inch lcd tv by dell wont turn on as if no power
if this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
boonys
  • 21 Answers
SOURCE: No Picture or Sound from ASTAR 32 inch LCD Television
Google Allelectronics or Hosfelt Electronics for these caps
I just ordered these at a good price but ordered 35Volt instead.
Also replacing 3300uF caps too as they are bulged at top.
Hope this fixes it. Will let you know.
Posted on Jan 21, 2008
SOURCE: stripes on screen
This is just a poorly designed TV, it has thermal problems, if you notice there is room for a fan at the top, but they left it out. I have had the power supply die and I fixed it, no help from Niko. I have resolved to let this tv die when it is ready now and move on. An expensive lesson on early adoption of cheap off-brand products.
Posted on Apr 14, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
joedirty
  • 158 Answers
SOURCE: I have an AVOL ALT3213M TV 32
Yes, I had the same problem and it was the invertor board that controls the lamps .I bet ya that's your problem.Hard to locate parts for these lcd's.If you find a supplier please post.Have fun locating parts. It took me 2 weeks to locate one.
Posted on Jun 19, 2010
Blown up
It sounds that the LOT {Line Output Transformer] to your TV has damaged. Contact any experienced service technician to get it repaired.
Jan 05, 2013 | Samsung LE32B450 32 in. LCD TV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Sharp 32 in lcd tv has small horizontal black lines throughout whole tv
a model number may tell me more===trace lines at a slight angle?
More information needed here----
Mar 23, 2012 | Televison & Video
Haier hl32xk2 32 in lcd tv turns on but doesnt show picture or sound and no buttons work
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Haier HL32XK2 32 in. LCD TV
Picture turns off but sound is ok.
Tv turn now,pictures only flashes a few sec. than died,than have sound left only?Yes than ur tv have those 1 or 2 long board call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those long refurbishes 1 or 2 LCD inverter boards for the replacement.
Nov 21, 2010 | Digimate DGL32 32 in. LCD Television
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
