I have a Magnavox TV/DVD and i recently had a power outage. The power came back on and turned on the TV and the color of the TV screen is a purple or green tint. There is only a tiny circle about 1 inch in diameter that wasnt effected and is normal color. How can i fix this color problem myself with out taking it to the repair shop?
    Habit-Forming:
  • 139 Answers
Remove the the plug from the wall socket(power) plug it back after five minutes. If the power outage was caused by lightning, then it is most likely static on the screen.
Regards
Phillip
Posted on Sep 13, 2009
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
Main board issue on HPL4260N
You may have a bad lcd panel ( inverter boards or t-con board) or look for bad blown electrolytic capacitors in the power supply board on the secondary side of the power supply look for 1000mf10 or 10volts they tent to buble up and a brown color forming on top of them replace with same value, higher voltage caps are ok.
Mar 19, 2010 | Televison & Video
I HAD A POWER OUTAGE AND NOW MY MAGNAVOX DVD WON'T TURN ON, PLEASE AND THANKS
Unplug it for about 10 minutes. Plug it back in and see if that helps. If not then there must have been a power surge when power was restored in your home.
Dec 05, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I am trying to connect my portable DVD player to the TV in my hote; room. On the back of the TV there are red and white connection for the audio but not a yellow for the video. I have audio and i have...
You're connecting to an HD connection that's why you are seeing the purple and green.
You should have 3 composite inputs, ie. yellow, white, and green on the back, and on the side in addition to the HD ones you are currently plugged into.
Jan 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Philips Magnavox 27MT5405 TV problem with color
hi sir that thing hapen when the magnetic field around the screen is varies evry time the tv set is switched off then on after an hour may be , it comes to its normal magnetic field state and when not so there are two reasons 1- check for around the tv for any magnetic items ,speakers , cassette recorder or any magnetic motors clear the around electric items if not working after an hour of reset then refer to 2 2- there is an electronic element inside calles PTC it should be deffect it is a small three legs element and is giving the first power to the colis around the screen to make proper magnetic field check it by qualified person please please don't forget to rate the solution and remember i am here at your service regards ]
Apr 30, 2007 | Philips Magnavox 27MT5405 TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
