Question about GoVideo VR4940 DVD Player/VCR
Switchable RF input
How do I switch the RF output on my Go Video VR 4940 DVD/VCR from Channel 3 to Channel 4? The maual says that the RF output is switchable but doesn't say how to do it.
Press the channel selection switches at the same time until RF03 or RF04 display. Select the correct channel by pressing the UP ch. button.
Posted on Jul 07, 2008
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
RF Modulators and cable connections
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
on Aug 23, 2010 | Audio Players & Recorders
Can't find where to connect for dvd. no white,yellow,or red plug.
Hello, Thank you for the opportunity to help
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
rulds2008_40.jpg WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
Rulds2008 "ED"
Jan 27, 2011 | Zenith Z19A11S TV
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Auxillary channel for dvd
    You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
    Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
    If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
    This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
    If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
    May 17, 2009 | RCA Universal Remote Control
    I need playback channel for tv to be ch.4 -
    Solution 1
    How to set the DVD Recorder+VCR’s RF output channel
    Turn off the DVD Recorder+VCR, then press and hold
    CH (v/V) on the front panel for about five
    seconds to change the RF output channel (CH 03 or
    CH 04). “RF 03” or “RF 04” appears on the front panel display.
    Solution 2
    Cable Service With Cable Box
    If a cable box is required in your cable system, follow the
    instructions shown below. This hookup permits both TV and
    DVD Recorder+VCR operation.
    To view or record a CATV channel:
    1 Tune the TV to the correct video input channel.
    2 Set the DVD Recorder+VCR to the output channel of the
    cable box using the CH (v / V) or the 0-9 keys on your DVD
    Recorder+VCR (e.g., CH3).
    3 Select the channel you wish to view on the cable box.
    Please rate this a fixya
    Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
    Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
    What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
    If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
    Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
    I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
    If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
    - Jim
    Jul 03, 2008 | Televison & Video
    if you have two separate units, the best way is to connect s-video cable from the output of the dvd player to the input of the vcr. If not, second best is to connect the video/audio out of the dvd to the video/audio in of the vcr. Othwise the units may have a rf (75 ohm cable) output and the dvd usually sends channel 3 or channel 4 as an output when playing and the vcr must be tuned to this channel. Start the dvd, pause it, hit the vcr record button, then unpause the dvd.
    Nov 30, 2007 | Emerson EWR20V4 DVD Recorder/VCR
    Trying to watch vcr on channel 4, but the vcr is set to channel 3
    You can watch the TV programs
    with the tuner of the unit. (Usually
    channel 3 or 4 of the TV is
    available for the RF converter
    setting.) Be sure to connect the
    unit to a TV using the RF cable.
    Select channel 3 on your TV.
    Press [VIDEO/TV] on the remote
    • If noise appears, change the
    RF output channel of the unit to
    CH 4 by pressing [VIDEO/TV]
    for 3 seconds. The RF output
    channel will alternate between
    CH3 and CH4
    Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
    GoVideo VR4940 DVD Player/VCR Logo
    Top GoVideo Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
