Question about LG 24 in. LDS 5811 Built-in Dishwasher
We have an lg dishwasher LDS5811ST and there is an error code. LE or an or 2 capital E's with top missing off of the first E. We tried turning the breaker off for 20 minutes and there is water going into the unit at the fitting. This happened between loads. NO symptoms on the load before this happenned. Any suggestions. Thank you Kevin
  • 423 Answers
Kevin,
The LE error on the LG dishwasher means that the dishwasher believes there is a leak because the level of the water is decreasing between the time the wash or rinse cycle begins (with the proper amount of water) and before the cycle ends and the water is pumped out.
After you have ruled out a real leak (check closely underneath) then here is the next step. 99% of the problem with LE is caused by the drain hose not having a high point between where it connects at the dishwasher and the drain.
The fastest (but not best) way to fix this is create a loop in the drain hose raised high up underneath the counter top. Attach it so it will not fall back. The cause of the "leak" is the natural siphon effect that can develop when the drain hose has not high point. (exactly like the siphon tube you may have created in science class.)
Please report back what you find, OK?
Posted on Sep 12, 2009
LG Dishwasher LDS5811ST does not drain last rinse out. LE code displayed. Did the shutoff of power. Most say PCB assembly, some asy control board - ?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Feb 24, 2015 | LG 24 in. LDS 5811ST Stainless Steel...
Lds5811st won't drain error le
have to change control board on lds5811st water not draining on last cycle already changed pump
Nov 17, 2012 | LG Dishwashers
I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
I have a LG Dishwasher Model LDS5811ST. The code LE is showing and my water will not drain. The motor seems to be straining? What can I do?
( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked. Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
Mar 24, 2010 | LG Dishwashers
I have a LG diawsher, model # LDS5811ST that is
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
LE means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
You also should remove the door panel and check for a broken wire (usually the blue one)
If all the wiring checks out - it is most likely a broken or locked up impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | LG Dishwashers
My LG LDS5811ST has error code of IE Where do I
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
The filter of Inlet Valve is clogged
by water filter?.
The Impeller of Air Guide is bound
Jul 03, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE shown on a LG dishwasher model LDS5811ST and this code is not given on the standard error code list.
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Hope that helps you resolve your problem..
Regards,
Rick
Dec 13, 2008 | LG Dishwashers
LG Model LDS5811ST error code LE
LE is a motor problem.. You can find details in the service manual at this website link... http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Page 25 discusses that error code and possible solutions
Hope this helps...
Sep 06, 2008 | Dishwashers
LG dishwasher model lds5811st error LE
per instructions in other's posts, I removed door panel, but no wires broken, so called LG and local authorized LG repair and they tell me motor sub-assembly needs replacement, cost $160 for parts, $200 for labor, which is making a new dishwasher look attractive.
Jul 25, 2008 | LG Dishwashers
LG 24 in. LDS 5811 Built-in Dishwasher Logo
402 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
