Can't set the TVguardian
We just purchased the RCA DRC285 with the TVguardian option. We tried to set the levels but it won't let us do so until we give it a activation number. It tells us to call a phone number....we did....the recording tells us to go online to TVguardian/tech support......we did.....but does not have any info about our RCA DVD player or a activation code.
  • 1 more comment
  • whitjones Feb 06, 2008
    i need activation code or phone# to call the number it gives is no longer in service
  • chawaba Nov 26, 2008
    I also have the same problem phone# is no longer in service and website will not let you purchase activation code. My prognosis is the company is no longer in business. Wish they would quit advertising this hardware in dvd players since this is the only reason why I purchased this DVD player.
  • Anonymous Dec 06, 2008
    need activation coe for tvg
I had the same problem with a memorex and called a company called Family Safe. Their number is 1-800-828-4514. Leave a message and you will be called back usually by a man named Mike. He has authorization to activate this for TV Guardian. Somehow the last digit is being left off of the code on the machines so the website reads it as invalid. You will have to give him your credit card number but it is a safe site and he activated mine and called me back within minutes with my code. Hope this helps.
Posted on Jan 16, 2009
Player won't read disk
The laser pickup unit is faulty. It should be repalced.
Apr 29, 2012 | RCA DRC285 DVD Player
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
May 06, 2011 | RCA Televison & Video
How do i unlock the channels from a hotel tv i purchased? it's an rca j32430.
Hello
There are some methods to unlock RCA TVs which are give below. Try each of them and find out which method do unlock your RCA Tv.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. OK.
Apr 17, 2011 | RCA Televison & Video
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
Disney Princess DVD player
11/12/08 My 18 yo daughter took her Disney "Ramon" dvd player she received at Christmas yo college with her and I used the code a moment ago <play> 1234 <play> and it unlocked it for her immediately.... try it it might work for you as well! Good Luck!
Oct 29, 2008 | Disney Princess DVD Player
RCA DVD player model DRC285
try sticking a knife on the top of the dvd slot. don't put a lot of pressure to break it though. turn the dvd player on, and it may open. If this solves the issue, try not to put items on top of the dvd player because it will cause it to stick and not open.
Apr 02, 2008 | RCA DRC-285 DVD Player
TV:G
1 Press SETUP and the Setup menu will appear.
2 Use ^/v to select the OTHERS item.
3 While the OTHERS item is selected, press > to
move to the second level.
4 Use ^/v to select the TVGuardian item.
5 Press B to move to the third level.
6 Press SELECT/ENTER.
TVGuardian menu appears.
7 Press< > to select On of the TVG mode.
8 Use ^/v/</> to choose a desired setting.
9 Press SELECT/ENTER to confirm your setting,
then press SETUP to exit the menu
Nov 16, 2007 | Sanyo DVW-7000 DVD Player/VCR
DVD/CD player
If you are using the HDMI output, you must press the HDMI button on your remote control.
Nov 13, 2007 | RCA DRC247N DVD Player
Televison & Video Logo
561 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
