My computer sometime do not boot, I've got a black screen (No Signal) and hangs there until I unplug the computer from power line. My configuration is: MSI P35 Platinum Combo Bios V1.2(updated), Q6600, DDR3 Kingstone 1333(works like 1066), Power Supply 550W, MSI8600GT DDR3,WD 320GB,LGDVD etc. From the LED on my mainboard I've got Uncorrect instaled RAM...(maybe that will help) Please Help me , I will thank you forever tnx.
  • tosethebe464 Sep 17, 2009
    How to check my CPU?
    My ram is tested with Memtest,
    Operating system is working prefectly-Win Vista x32bit,
    before that I tested my cpu with Prime tester for about 24 hours, I have some temperature issue of 71*C but without any restart or shutdown. This problem happens sometimes not always, or every day but it's still a problem .. Tnx..
  • 674 Answers
There are a lot of causes of black screen.. check the ram, or cpu.. or the vga connector.. about the booting.. be sure that your operating system is good.. if not of course not booting anymore
Posted on Sep 12, 2009
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration...
There are different possibilities for system hang up. I want you to find it your self from following my simple instruction.
1. (when computer is turn on) Check temperature... overheating can cause system to hang up, it can cause the system to reboot, it can cause the fatal error message and turns your screen to blue. Overheating is cause by exhaust fan or blower not working. Find this blower or exhaust fan on top of the processor, as built in fan in your video card, attached on your power supply and on the casing of your computer. Replace non working fan or blower.
2. Check video card...faulty video card can cause your system to hang up. It can cause also your system to go on blank screen. Most common problem is loosen connection of video card from the motherboard. Disconnect and reseat the video card properly. Inspect the fan, if not working then video card will overheat and system fail. If you previously see moving colors in your screen especially small boxes, or discoloration and screen going black and white then it means video card is already failing. You will need to replace it.
3. Check for hardware failure. keyboard, mouse lan card can cause your system to halt and hang. You will need to disconnect this first when booting and see if by removing this hardware will complete the system to boot up to operating system. Replace faulty one.
4. Harddisk failure. when computer reset or will not boot up completely then hard disk usually cause this problem. Initial remedy is to reseat its connection sata, ide or power supply connector.
If you hear ticking sound in the harddisk or excessive vibration then it will need replacement.
5. Operating system corrupted. this can cause your computer not to boot up properly and hang the system. Reformat and reinstallation of operating system is required.
6. Power supply failure. you need to check the output voltage. dropping of voltage can be cause bi leaking capacitor in the power supply unit. replace it with exact value. Voltage should read +12VDC for yellow, +5VDC for red. and should be stable even with load.
let me know which one cause it.
Feb 07, 2011 | Intel D845GVSR Motherboard
TODAY AFTER ONE YEAR WORKING PERFECTLY,MY E-MACHINE GATEWAY MONITOR,SHOWED :OUT OF FREQUENCY RANGE AND TURNS BLACK,AND COMPUTER HANGED FOR A WHILE,TILL I UNPLUGGED FROM POWER CORD AND REBOOT IT. WHAT WAS...
If the computer hangs for a while and reoots and then works the monitor, it tells me that the signal to the monitor went dead until rebooting. It is as if you unplugged the monitor from the vga or dvi card, or it was getting an incorrect signal from the vga or dvi card. It may not be the monitor, so much as it is the computer doing this to the good monitor.
One can test to see if the monitor is bad by using it on another computer tower or desktop to see if it does it there. Good luck on this diagnosis.
Feb 03, 2011 | E-Machines 17" Widescreen Flat Panel LCD...
Black screen on Boot
1. Check the memory modules are correctly installed.
2. Check that all the installed ram is DDR3 - this board will not accept DDR2 andDDR3 together.
3. If you have more than one memory module remove one and try booting. If all is ok try just the other one.
4.Try with DDR2 memory
Oct 30, 2009 | Intel Motherboard
Acer Aspire 5735Z - Vista Home Prem. shutdown hang
updates can be slow,and lead to more updates sometimes.you should goto windows update,let it search for important updates then install them.even if it takes a while,once you do that it should be fine.and configure updates to auto download but ask to install.
Sep 20, 2009 | Acer Aspire 5735-6694 Notebook
Windows xp is not booting. the computer is turning on and displays the p5vd2mx welcome screen, but then goes to a black screen with a flashing white line at the top left corner of the screen. furthermore,...
Have you dusted out your PC lately with some canned air? If your system is hanging up, it could be an overheat issue. Usually this will cause a reboot, but sometimes it will just stall and you have to do it yourself.
Jul 04, 2009 | ASUS P5VD2-MX SE Motherboard
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
Hang-ups durring bios screen and hangs at certain times.
hallo, i'm Fernando Kendy from Jakarta, Indonesia
hope i can help with this problem
the mainboard has onboard graphic adapter (S3 bla bla bla)
try using it. unplug your nvidia FX5500
how is it? does it work?
if it still not working, then STOP here. something is wrong with your mainboard
if it is working, then goto BIOS configuration
change the PROCESSOR frequency to 100 MHz (MANUAL) and the RAM frequency to 400MHz
save the configuration, and shut it down immediatelly
plug the nvidia FX5500 back, and turn your pc on...
it should be working fine now
but if you still have problem, then i'm sorry... couldn't help you any further... :)
Sep 08, 2008 | ASUS P5VDC-MX Motherboard
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
