Question about Ubi Soft Entertainment Asphalt Urban GT for DS
You *** wads
Hi gat
  • 69 Answers
Stop being a bastard
Posted on Oct 30, 2009
Couldn't load gfx.wad
The WAD file type is primarily associated with 'Game Archive'. The WAD file extension is often used for game archives. These are usually packages containing levels, graphics and other game data, and the term WAD is often used to refer to modified versions of these files. WAD stands for Where's All the Data? and the term generally started with the Doom series of games.
assuming you have gtx.wad, that file is associated with Counter Strike, you can't just run it as it s system file for Counter Strike/ Half Life 2 What are attempting to accomplish.
May 19, 2011 | Computers & Internet
Tip
Wii - How to SoftMod, Guide.
This post will explain How to SoftMod Nintendo Wii on any firmware, Region and make its Homebrew enabler for play Wii games, backup, Homebrew applications on your wii, And all without needing a wii modchip!
Requirements: A SD card, (1GB should be enough for Installer and Backup), formatted to FAT32. Some SD card is not compatible to be used to backup the wii nand, but its work for use as boot2 of bootmii, so you might be need 2 different memory, for installation and nand backup.
Download: All files can be found **Here..!
*SD Card Pack
*cIOS38_rev14-Installer
*IOS60 Patched.
*Trucha Bug Restorer
*WAD Manager v1.4
*AnyRegion_Changer_v1_1b
*AnyTitleDeleterDB
*Backup Launcher WBKL
*Firmware Updater v4.1 -299Kb. (Need Wi-Fi connections).
*preloader v0.29 -214Kb. (OPTIONAL).
Installation Procedure:Adding Files.
  1. Extract ‘SD Card Pack’ and copy all contents to the root of SD Card, and copy a second of ‘IOS38-64-v3610.wad’ to ‘wad’ folder - ‘SD:/wad/’.
  2. Extract ‘cIOS38 rev14 Installer’, ‘Trucha Bug Restorer’, ‘WAD Manager’, ‘Any Region Changer’, and ‘Any Title Deleter’, into ‘apps’ folder - ‘SD:/apps/’.
  3. Extract ‘IOS60 Patched’ and ‘Backup Launcher WBKL’ into ‘wad’ folder - ‘SD:/wad/’
  4. Preloader is also an optional install, if you don't want it just skip.. Extract ‘Preloader’ into ‘apps’ folder. ‘SD:/apps/’.
  5. Extract ‘Firmware Updater v4.1’ into ‘apps’ folder. ‘SD:/apps/’. This updater require wi-fi connection, If you want to use offline updater, you will need wad updater (*.wad) and put its into ‘wad’ folder. IMPORTANT!! Make sure you have select the right one for your region..! E=Europe, J=Japan, U=USA, if you use a firmware from a different region, it will BRICK your Wii.!
Install BootMii & Homevrew Channel.Homevrew Channel is a channel on your wii menu that will allow you to put applications (homebrew) on your sd card and put them on your wii, this may include emulators, games, and installers.
Insert the SD card into Wii. then, Go to ‘Wii Options’ > ‘Data Management’ > ‘Channels’ > ‘SD Card’, then you will get a message saying ‘Load boot.elf?’, select ‘Yes’ and the Hackmii installer will run.
Press ‘A’ to continue, Install the ‘Homebrew Channel’ (HBC), and follow the on screen instructions. When done, the HBC will appear on wii channel.. Now go back and install ‘Bootmii’ as ‘boot2’ (recommended), if you can't install it, try different SD card. When it done, reboot your wii with it SD card, and wii will load into BootMii menu..
Backup Wii NandMaking a NAND Backup with Bootmii is highly recommended, it will recover your Wii from bricks. make sure there is at least 530MB free on SD Card.
Boot Wii into BootMii menu, if bootmii is installed as an IOS, go to the Homebrew Channel, press ‘home’ on your Wiimote then select ‘Launch Bootmii’.
Readmore...
on Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Wii - installed a .wad now get black screen
I hate to scare you but that's not good. You might have bricked your Wii by installed a bad .WAD -- installing a bad WAD will most definitely brick your Wii. Hopefully you did a backup using BootMii before you did that and backed up your Wii's NAND. Thats the ONLY way you can restore your brick Wii from bad .WAD installs. Here's a few great guides that might help you unbrick your Wii.. good luck!
http://www.wiilovemario.com/The-most-up-to-date-Wii-Homebrew-and-Backup-tutorials-known-to-mankind
Sep 30, 2009 | Nintendo Wii Console
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Canon ir210s gatting error E100
that is a defective laser error code sorry
Dec 23, 2008 | Canon imageRUNNER 210S Copier
Can i unlock a nintendo wii console to play NTSC games
right u want to soft mod your wii it is realy easy to do this ist u need is an sd card
http://bannerbomb.qoid.us/aads/aad1f_v108.zip
http://www.yafaze.com/wii/files/4.0softmod.rar
Put the contents of both zips on your SD Card as it is in the zip, just drag all to SD Card.
Go to Data Management then choose Channels followed by SD
Choose "Yes" to load boot.dol
LoadMii will then load.
Press "A" on the WiiMote.
Go down to DowngraderIOS35.dol and run it by pressing "A" on the WiiMote.
Choose downgrade IOS35 and then let it go, then choose exit (ignore the patchmii and dvdx)
You'll be back in LoadMii now.
Go down and run Wad Manager 1.4 by pressing "A" on WiiMote.
Just select normal settings (don't change IOS)
Install IOS35.wad.
Exit Wad Manager 1.4 by pressing "HOME"
You'll be back in LoadMii.
Run Wad Manager again, Select IOS35 when it asked what IOS to use.
Install the CIOSv7.wad.
Press "Home" to exit.
Then Run Wad Manager again.
Tell it to use IOS249.
Install IOS36.wad, BUL3g.wad & HBC.wad
Sep 29, 2008 | Nintendo Wii Console
Wab cam
Same way you gat fine quailty on any other piece of hardware. Plug it in. Try it out. If it sucks you need a better webcam.
Jan 21, 2008 | GE EasyCam Plus Webcam
Thread wadding up
Tension!!!! Its all about the tension! I just had this issue after loosening my tension. So tighten it - the higher the number the tighter the tension. My tension is set at 6 on a Singer 9005 and it seems to work great. By turning it down to 4 I ended up with huge loops/wads of string. Hope this helps!
Nov 03, 2007 | Brother LS-2125 Mechanical Sewing Machine
Can someone please help
Ok, the PSP emulator is a program that emulates the work of PSP on your computer, and take a portion of your PC's CPU to emulate the PSP's Processor. Or you can say it's a program that runs your PSP games through a window. To Run your "Doom on PSP" I can paste some text from the readme.txt inside this file: http://psp-news.dcemu.co.uk/files/doompspv005plus.zip Release Notes for Doom-PSP 0.05 plus: To Install fw 1.0 and 2.0(with loader) 1. Create Doom dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw10 into doom dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. fw 1.5 1. Create Doom dir under Games. 2. Create Doom% dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw15/Doom into doom dir. 5. copy eboot.pbp from fw15/Doom% into doom% dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. Then give us feedback. Play nice with your PSP. Goodluck
May 17, 2007 | Sony PlayStation Portable (PSP) Console
Ubi Soft Entertainment Asphalt Urban GT for DS Logo
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
