Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
I took the cover off the brush so I could cut off all the hair that was wrapped around it (vacuum was working fine, I just noticed the hair). I pulled the brush/spinner thing off one side, cleaned everything, popped it back in where it belonged, and tried to make sure the belt was in the proper alignment. However, when I turned the vacuum on, it makes a horrible noise like I'm sucking up rocks. What have I done wrong in putting it back together? It seemed simple...
  • nursenancy4t Sep 14, 2009
    Thanks. The roller brush is replaced correctly, but I think the problem is that the belt won't center itself. When I center it, it just goes off track when I turn the roller brush. I may have to take it in :(
  • 281 Answers
The ends of the brush roller have to go in in a certain position.each end has a different look.make sure the match up to the seats on the roller guides and make sure the belt is centered.the belt will center itself by turning the roller by hand in one direction then the other.the ends of the brush roller ust set in their seats correctly
Posted on Sep 13, 2009
How to clean the rotary brushes on the bottom of the vacuum
Just use a razor knife to cut through the hair, string, etc. that may be wrapped around the brush. It is easier if you take the brush out of the vacuum and that will also let you examine the bearings at each end to see is they need to be cleaned as well.
Mar 09, 2014 | Oreck XL2600 Vacuum
My floormate is not suctioning very well. Tech support told me to take out the brushes and put them back in and this helped for a little bit then it went back to not suctioning. deb
When you took the brushes out, was there hair wrapped around them? Sometimes they just need to be cleaned off. When you take them off, there is a belt they connect to that also goes around a gear -- make sure the belt and gear don't have hair wrapped around them either.
Hope that helps!
Aug 28, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise coming from DC07
Sometimes the brush bar may be slightly bent and has been rubbing against the yellow housing part (at the hole where the belt is) and has melted part of it off, the part which holds the brushes in place. The noise may the bar vibrating against the yellow part because they are now loose. Unfortunately you may have to replace both parts.
Feb 05, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson absolute 17 animal smells like its burning when turned on also has terrible noise...nothing wrong with belt already checked it..so what's going on
I had the same problem with my DC15. With the brushes going it smelled like burning hair (bad). I had cleaned the brushes many times and it didn't seem to help. I even took it into a Dyson authorized repair shop and they couldn't find anything wrong with it. As a last resort I called Dyson 866-693-9766 1-866-My-Dyson. I was on hold for about 15 minutes before getting a live person. He had my problem diagnosed in literally 1 minute. I had hair wrapped around the spindle, inside the brush/roller mechanism. He walked me through taking apart the brush mechanism (super simple only using a quarter). There was a TON of hair crammed around the spindles and inside the brushes. All wrapped very tightly. I hung up with him to do the cleaning. It took some time and I had to use tweezers to get inside the rollers/brushes. But I got it all, put it back together (which was really easy) and tested it out. No burning hair smell at all. FIXED!
Nov 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Dyson animal
sounds like you may have alot of hair or thread wrapped around the bar, this can stop it if there is enough, have a look at the beater bar (brush)
Jun 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Mar 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
