Question about Whirlpool Calypso GVW9959K Top Load Washer
My washing machine makes noise when I go to start it. One of the hoses starts to shake? What can this mean?
  • 61 Answers
Might want to check the screens in the hose ends.
Posted on Sep 12, 2009
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing machine makes banging noise when washing
This usually means the clothes are not loaded evenly. Try redistributing them and see if that helps
Sep 08, 2012 | GE G.e. Gtwn4950lws He Top Load Washer
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
My washing machine has started making a noise when it should spin, and doesn't drain on the spin. It Starts the cyle ok, and drains, but the problem is when it spins. It isn't spinning at speed - it is...
Either your pump or filter or outlet hose is blocked Clean out the filter/pump and make sure the outlet hose is not blocked.
Difficult to help without make/model??????????
Jan 27, 2011 | Washing Machines
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire front load washer - e10 and water hose shaking
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
