Question about RCA HD52W66 Projection Television
Convergence The red, green and blue lines are out of alignment and I do not have a convergence option in my set up screen.... what do I do from here ?
  • 1 more comment
  • misskimmie Dec 11, 2007
    The television is an RCA model # hd52w66
  • Quinn Carollo Dec 29, 2007
    same model and the same problem, i just paid $185.00 to have this fixed and 2 weeks to the day it has messed up again.
  • Anonymous Mar 07, 2008
    i just bought this tv and the convergence is messed up. ive had it a year and 3 months. not what i would have expected out of rca a name brand tv. if they only last a year i will not go back to this brand. the dealer i bought it from says to contact rca beacause they are responsible. please let me kbnow what to do. im at my wits end with trying to get some help.
    President:
  • 4,402 Answers
Convergance ic are bad and maybe resisters.
check this site out:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Mitsubishi Medallion - The green convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 15, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
I have a hitachi 50FX18B and the convergence lines...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 23, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
RCA HD52W66 Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
