Question about Dremel Tools & Hardware - Others
Broke small phillips screw head off the end of dremel
I tightened the small phillips screw on the end of the dremel to tighten down a circular sanding piece. I tightened too much and the head of the screw broke off. Is it possible to remove the screw that has almost nothing sticking out now?
Pete
  • 2,176 Answers
Possible if you have a drill bit smaller than the screw and you can try drilling in reverse. Might be better just to replace the mandrel though.
Posted on Sep 12, 2009
The collet nut won't completely tighten down to keep a drill bit or what ever I'm using in place .
make sure nothing is broke down inside of it or some type of shavings try sprayin wd40 down it
Feb 08, 2016 | Bosch Dremel 4000 Rotary Tool Kit...
Sorry I dont know the names to all the parts, but everything works on mine but when i press the button down to change out the heads it doesnt work and i cannot tighten or un-tighten it (though currently...
contact them direct at dremel.com and you can download a schematic which I think the locking collar/mechanism is rounded but they also have a toll free number for technical support.
Jan 08, 2011 | Dremel Variable - Speed Multipro Rotary...
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
How do you change out sanding drum (on mandrel) when sanding drum is worn down?
loosen the screw on the top of the mandrel. pull drum off rubber insert. the mandrel works by expanding and creating pressure on the sanding drum when screw is tightened. it does take a little pressure
Jun 21, 2009 | Dremel 300-N/55 300 Series Tool Kit
I nee to tighten up the freezer door handle on a sub zero 650?
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Apr 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
'99 Hansgrohe Aktiva Family Set. All heads & controls are leaking
the temp control knobs have little plastic tabs over the hot and cold handles. To remove them take a flat blade screw driver( small with sharp head) or a small pen knife( cover drain with a wash cloth
and pop the tabs off
Take a medium size phillips screw driver and tighten the screw
Put tab back o and you are done
If they work loos again remov e tabs, screws put loctite ( You can get a small tube for m ace or hd) screw threads and tighten
Temp control knob either has same tab or has a hex type of set screw or has a large lock nut
use a channel lock pliars over nut ( protect chrome finish by putting washcloth over then put wrench over cloth
You mentioned heads I am assuming shower head you need to use an adjuatible wrench to turn the nut (at head) and a vice rip or chanel locks over washcloth around the eustaceon ( chrome pipe coming out of wall
If you have teflon tape put that on the threads of showr head and tighten
Best of luck to you!
Nov 18, 2008 | Hansgrohe Plumbing
GE Monogram ZBD0710 Dishwasher
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.  Here's what to do.  You must fully remove the handle from the appliance.  Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.  There is no need to remove the end caps.
Mar 27, 2008 | Dishwashers
Tools & Hardware - Others Logo
128 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
