Question about Microsoft Xbox 360 Console
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
    Sniper:
  • 92 Answers
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Posted on Sep 13, 2009
  • 23 Answers
Wat flat always does not mean hd sometimes flat means flat panel no hd there ok by regular tv iam taking into account a completely basic tv so yeah some really basic tvs donot support the least required resolution also u can try changing the av cables as there are 2 types of cables available eg hd and regular
Im trying to hook up my xbox 360 to my digital lifestyles flat screen and cannot figure it out :((
A USE HDMI CABLE FROM XBOX TO TV AND SELECT HDMI AS THE IN PUT ON THE TV OR USE A HDMI TO AV CONVERTER AND PLUG AV PLUGS IN TV AND SELECT AV IN PUT ON TV
Jun 08, 2014 | Video Game Consoles & Games
Game console hook up
What type of hookups are on the back of tv ? Do you have an HDMI hookup if so try using that If your tv comes with a game mode look in back before u hook it up to place it in right spot. One last thing why don't you try hooking up old fashion way buy adapter for regular cable hookup and use channel 3 or4 that might help
Jul 30, 2012 | Mitsubishi CS-32307 32" TV
Turn on xbox 360 and the tv shows blue screen only
make sure all your cables are hooked up in the corresponding ports, and also make sure that you have the video/audio output cord switched to the right setting for your tv (HDTV/ regular)
Dec 31, 2010 | Microsoft Xbox 360 Console
When I hook up my xbox 360 to a floor model flat screen that is probably 7 or 8 years old, there is sound but no picture. When we hook it up to our newer model flat screen everything works fine. Can you...
Are you trying to use HD? Component cables or HDMI? Component cables limit you to 720p. It's possible that your old TV doesn't support 720p or there is something wrong with the jacks. What sort of connections do you have?
Sep 03, 2010 | Microsoft Xbox 360 Console
It wont hook up to any other tv except for flat screens
the xbox 360 connects to vga scart(WRY) socket and hd socket with the correct cable
Jun 04, 2010 | Microsoft Xbox 360 Console
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
Need to hook up microphones for lips on xbox 360 i have lost instructions
you ahve to use a regular xbox 360 to setup then use the mic
Jun 02, 2009 | Microsoft Xbox 360 Console
HOOKING UP XBOX 360 TO HDTV
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Feb 19, 2009 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture
Try looking on your AV Cable there is a setting for HDTV and TV if you have a High Definition tv use that setting but by the sounds of your issue i would say you dont and would go with the regular TV setting. Its right on the neck of the AV cable where it plugs into the game console. Let me know if this works for you.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
