Question about Brother (FAX565) Printer
I have a brother fax565 and have no dial tone
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Have you tried pluging in a normal phone to your wall socket?
Sounds as if it may be a fault with the line/socket.May also be that the Fax LIU board has failed/been hit by lightning.
Posted on Oct 05, 2009
    President:
  • 2,600 Answers
Make sure that the phone line is in the right jack in the back. There may be two jacks one marked line, one marked phone....make sure your line for the fax is in the jack marked "Line" then if you want a phone attached to the fax for calls, run a phone line to the jack marked "Phone".
Posted on Sep 12, 2009
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How can i fix the troubleshooting and routine maintenance problem on my brother mfc-7340, i cant receive fax or send.
Plug a phone into the jack and see ifyou have dial tone. if you do then check to see if yo have dial tone when you select hook on the printer. If you do have dial tone then make sure you are pluged in the back in phone not ext. if that is not it then make sure you unit is on fax only.
Jan 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
No dial tone to fax documents with Brother Model
This issue was addressed previously by another FixYa expert. Read the entire post before attempting any repairs. Hope this helps
See:
http://www.fixya.com/support/t1234332-mfc_440_cn_out_memory
Dec 11, 2009 | Brother MultiFunction Center MFC-440CN...
Brother 575 phone does not work?
If you can send fax out, your handset should have dial tone. If there is no dial tone, try to replace the handset cord.
Sep 17, 2009 | Brother FAX-575 Plain Paper Thermal
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
Intellifax 1270 lightning damage. no dial tone
Plug a regular phone into the wall jack to verify that you have a dial tone.
Nov 06, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
No dial tone
Sounds like the phone line may be dead, try to put another phone on that line and make sure the phone line is active.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother (FAX565) Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
